Quick Engine Question
Old Apr 28, 2008 | 11:33 AM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
I'm going to swap a newer beta into a 99 tiburon with a 5spd. Some places I've called say that I have to get a beta from a car which has a 5spd as well. And some say it doesn't matter if it came from an auto or 5spd. I just need to know which is true.
Thanks.
Old Apr 28, 2008 | 11:38 AM
BlueRD2's Avatar
I dont believe it matters unless you changing the tranny too, an engine is and engine a tranny is a tranny.
I dont believe theres any differences between the engines of a auto and a manual.
Old Apr 28, 2008 | 11:42 AM
Doesnt matter.
Old Apr 28, 2008 | 11:52 AM
rollwitstyle's Avatar
you will need a new flywheel, the auto one will not work, nor will the clutch.
Old Apr 28, 2008 | 11:55 AM
BlueRD2's Avatar
If he keeps his same tranny then he will already have one.
Old Apr 28, 2008 | 12:02 PM
Whiplash's Avatar
I already have a 5spd tiburon...so I was thinking I can use the clutch/flywheel that I already have. Yes? No? All I'm doing is replacing the engine.
Old Apr 28, 2008 | 01:22 PM
you WILL need the trans plate from a 5spd beta and you WILL HAVE TO MOD IT. check out the thread from my swap it will tell you EVERYTHING you have to do.
http://www.rdtiburon.com/index.php?showtopic=25891&hl=
Old Apr 28, 2008 | 01:27 PM
Whiplash's Avatar
So I should just find an engine from a 5spd...thanks.
Old Apr 28, 2008 | 09:03 PM
Not really man. And Optimo is talking about the beta2. If you get a beta1 you will have no problem at all.
If you are talking about the beta2 you will need to mod the plate either way it sounds like.
By newer beta I took it as a lower mileage beta1 which would be very easily swapped in.
Old Apr 29, 2008 | 05:19 PM
Whiplash's Avatar
Oh well I bought an engine from a 5spd.
