O2 Sensor Extension
Old Apr 30, 2008 | 09:42 PM
bassboy3313's Avatar
Vehicle: 1997 Hyundai Tiburon FX
does anyone know where i can find O2 sensor extensions for the RD1?
Old Apr 30, 2008 | 09:44 PM
Nne are made specifically. There are threads on this, and I did post some links in the past to sites that sell extensions, you'd have to find one that works though.
Old Apr 30, 2008 | 09:54 PM
yeh... man, i hope you don't have the same problems as i did.
http://www.rdtiburon.com/index.php?showtop...0&hl=sensor
bullfrog found the official color diagram. that is it, but i made the plug diagram as there is none. it worked for me for 1 month before i got a CEL but i think i have a bigger problem than wiring... i dunno, i have sh*tty luck and make sh*tty decisions so don't take my word for it.
Old Apr 30, 2008 | 10:13 PM
I decided I didn't look too hard the first time, so here's some legwork for you.
http://www.jegs.com/p/Caspers+Electronics/.../10002/-1/11523
This one on that page looks like it MIGHT work.
http://www.jegs.com/i/Caspers+Electronics/...10002/-1/751937
No way to know unless you pull one of your o2 sensors and try to plug it into a plug from this model year GM. Or you could order one, try it, and return it if it doesn't fit.
Looking a bit further, I found the site for Casper Electronics.
Check this link out.
http://www.casperselectronics.com/mm5/merchant.mvc?
Type in "Extension" in the search box and look about 1/2 way down the page.
http://www.casperselectronics.com/mm5/merc...;Category_Code=
That one might work.
Also look at the bottom of that page, more links.
There's another.
Even better, I've got my o2 sensor off my car and went and looked. We have a square connector, 4 connectors. Looking at that site, and comparing the connections and how the slots slide in, the DODGE ones would work, looks like 100%.
24 Inch.
12 Inch.
For better pics, look here.
http://www.installationinstructions.com/109210.pdf
I'd say that's a match.
Anyone else wanna confirm?
Compare with the pic in this Ebay Auction.
http://cgi.ebay.com/ebaymotors/O2-OXYGEN-S...sspagenameZWD1V
OUrs looks identical to that, but yellow.
Old Apr 30, 2008 | 10:15 PM
ThisCelluloidDream's Avatar
my O2 sensonr has been getting gunked up lately and has been making m engine misfire...will the extension help that?
Old Apr 30, 2008 | 10:49 PM
daafisch's Avatar
The dodge ones look pretty close.
I know a while back I bought the honda ones because they looked pretty close but were off just enough that they wouldn't fit. The biggest problem came with the depth at with the connectors on the O2 sensor so keep that in mind. It may look like they will fit but the plug might be a little too long
Old May 1, 2008 | 06:08 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
QUOTE (S0VERE1GN @ May 1 2008, 12:15 AM)
If your o2 sensor is getting fouled you may want to find the cause of it before you decide to move it. Moving it just hides the problem as you still have something wrong going on to foul it in the first place.
Nice legwork Zman this is defiantly going to help out a few people if fits. HKC for one.
Old May 1, 2008 | 08:01 AM
It should fit. Color coding FTW.
