Question- Random or Red field this one
ALright, my buddy has a 96 Mitsu Eclipse GSX (AWD Turbo). Hes getting a new Turbo to replace the stock one. He said once he gets it installed, he will give me his stock Mitsu Turbo. Any possible way I can make it work on my Tibby??? Anything at all, a free turbo is a hard thing to pass up. Thanks.
As We've both stated before. You can use just about any turbo. Finding the exhaust manifold is part of the problem.
I believe that the Champion Manifold from Korea will fit the stock Mitsu turbo, but you will have to check with Cheuk over at Fxtreme to Be sure.
You then need an intercooler, lots of plumbing, a new full exhaust, 4 larger injectors, a blow off valve, wastegate if that turbo does not come with one, and some form of ECU trickery (SAFC, Uni-Chip, HalTec, Motec...etc..etc..) and lastly...someone to tune it all.
The turbo is only about $300 to $1000 of the $2000 to $5000 custom turbo package.
