PU motor and gearbox mounts
Old Mar 4, 2005 | 03:44 AM
  #21
techcontib's Avatar
QUOTE (Mad-Machine)
That may be true.. but if you have never driven a Supercharged car instead of a Turbo.. they hit pretty good from idle on up. I think Xorro is a leadfoot and has beated her mounts into submission.
Its doesn't help either when the sucker ways a ton and is on top and back of the motor off setting weight. I have marks on my firewall and slight rubbing on my hood.hehehe
Old Mar 4, 2005 | 06:01 AM
  #22
Xorro's Avatar
Vehicle: Mitsubishi Lancer Ralliart GSR
QUOTE (techcontib)
Me too!
Its was the fact that the pulley was severly grinding on the hood that signalled the problem with the mounts.
Old Mar 4, 2005 | 06:08 AM
  #23
techcontib's Avatar
QUOTE (Xorro)
Me too!
Ouch. Mine are marks on the gear housing that attaches the pully drive to the s/c. The firewall is from the stupid idle bypass valve which I have fixed. I might get some mounts when I get home as well.
Old Mar 4, 2005 | 06:14 AM
  #24
Something you may want to look into. I believe the 240SX guys have a hydraulic damper than mount between the head and the strut mount. They do this to keep the engine from torquing from side to side.. but it would probably work (with some fabrication) to keep a front engine from moving fore and aft.
*edit*
Found one!
http://www.240sxmotoring.com/entodaforni2.html
Old Mar 4, 2005 | 07:20 AM
  #25
Xorro's Avatar
Hopefully the uprated front and rear motor mounts will do the trick, although that damper is a good idea.
