Project Gasmilage
Old Aug 5, 2005 | 01:04 PM
  #31
supercow's Avatar
Fuel Data
Fuel Tank Capacity: 14.5 gal.
EPA Mileage Estimates: (City/Highway)
Manual: 23 mpg / 31 mpg
Automatic: : 21 mpg / 30 mpg
Range in Miles: (City/Highway)
Automatic: 304.5 mi. / 435 mi.
Manual: 333.5 mi. / 449.5 mi.
guys there's the facts from edmunds.com and thats what hyundai said a new tib should get. Unless you drove downhill for 300 miles your not getting 40 mpg, in other words it's possible but you'd have to be in ideal conditions most of the time you'd need to be idling going downhill. (usually I am getting 29-31 depending if i did more in town or highway that fill up)
the only way to do this is to set your trip when you fill up. Then the next time you fill up divide the # on your trip by the # of gallons you put in. If your wheels are some crasy size or your speedo's off, your not getting accurate numbers. for instance the other day my speedometer said 55 one of those radar machines on the side of the road said 54 and i'm on stock wheels.
Number of miles driven= mpg
number of gallons used
and no you can't just divide by 14.5, well you could but you would need to run it till it's dry as in broken down on the side of the road(thats what the range #'s are above). btw, my fuel guage hits e when i still have 4.5 gallons (used 10). if i fill up right when the idiot light comes on I still only put in 12 gallons. I think some of your guys methods are super screwed up.
Old Aug 5, 2005 | 01:34 PM
  #32
Screwdriver's Avatar
On a side note, its interesting that a 3.5L 280 HP V6 can get better gas mileage and accelerate to 60 in 6.6 seconds, despite weighing so much more.
Im talking about the new Toyota Avalon which gets an EPA rated 31 mpgs. Amazing in my opinion.
Old Aug 5, 2005 | 01:36 PM
  #33
Double_A's Avatar
Mr. Supercow, i think your remarks are super screwed up. Do you realise that i average 30-31 MPG when im driving around town. I always fill up and almost everytime i check my MPG. Its easy, i have a calculator on my phone so its very easy to figure out exactly what im getting.
THis is starting to get me a lil anrgry that sombody is telling me what my car is doing, with my driving habits, with my recording of information and doubting my abilty to properly check my gasmilage.
Also Supercow you wrote that the EPA ESTIMATES 31MPG highway. SO that would not be Hyundai's numbers, that would be numbers ESTIMATED by the EPA.
Im going to go take a pictures tonight to prove that right now im getting more than 31 MPG. With a mixture of highway/city.
Old Aug 5, 2005 | 04:38 PM
  #34
Dmitry's Avatar
Vehicle: Elantra HD / 2007
QUOTE (fonseca @ Aug 5 2005, 06:48 AM)
I'm skeptical that shifting below 2000 rpm is more economical than shifting at 3000 or higher, which is what I do.
Agree. I think shifting below 2000 RPM will give you more load on the engine then shifting at 2500-3000 RPM. Same with cruising. More load = more fuel.
Old Aug 5, 2005 | 04:50 PM
  #35
Double A is correct... those are EPA estimates as produced by their computer controlled "driver" on a closed "course" using "average" driving.
Also, like him.. I average 31 mpg just about everytime I fill up. That is a combination of highway, backroads, and city driving...
And yes, you do check your average fuel economy by setting your trip when the car is full, and then when you fill it up again, you divide the number of miles driven by the number of gallons you used. You do not need to drain the tank to bone dry to figure out your MPG.
Now then.. let's keep this civil. Any flaming will result in points. Do not think I am arbatrarily taking Double A's side.. I have seen those kinds of fuel averages in my own tib, so his is not a fluke.
Old Aug 5, 2005 | 04:55 PM
  #36
JL_TIB's Avatar
k filled up from same spot i was at last time'
i could only get 13.6 gallons in it
went the same distance
Old Aug 5, 2005 | 06:23 PM
  #37
Korean_Redneck's Avatar
Vehicle: 1999/Hyundai/Tiburon
I got
Shell conventional oil
Hyundai oil filter
2 doses of auto-rx engine flush
Hyundai spark plug wires
NGK V-powre spark plugs
87 octane fuel
every 10,000 miles use Chevron Fuel system cleaner
I got about 36 MPG A/C on City/Highway mix.
Old Aug 5, 2005 | 10:57 PM
  #38
supercow's Avatar
QUOTE (Double_A @ Aug 5 2005, 01:44 AM)
JL_TIB - Yea man, its not really a good idea to just let your car run till there is no fuel just to see how many miles per tank you get. Most people dont let it go all the way down to nothing. The most i ever had to fill at once was 13.5 gallons. Dude are you sure your really filled it a full 14.5 gallons. Cuz if so that is horrible milage. Your looking at 24 MPG, ive never had it that low. I mean when i first got my intake i drove like a nut for aout 2-3 tanks and i never saw anything lower than 25 MPG.
44MPG is no lie. I swear that is what i got. And like JL_TIB said. It doesnt take a rocket scientist to figure out your gas milage.
Like i said that was with new plugs, oil, air filter, 2.5 full exhaust and using cruise control. Im tellin ya. If you dont drive fast on the highway the tib can put up amazing numbers. Really think about it, when on the highway for that long the car is just cruisin and can lean out safely.
QUOTE (Mad-Machine @ Aug 5 2005, 05:50 PM)
well about the epa estimates, i didn't know that i figured thats what hyundai reports, US probably checks it out and passes it along. I also get 29-31 on every fill up.
anyways what I was talking about was 44 mpg and the "i got this many miles on a tank" (no reference point). I'm not flaming but 44 mpg is impossible unless (like i said) he was going downhill for like 300 miles.
QUOTE (honda hybrid stats)
Fuel Tank Capacity: 13.2 gal.
Manual: 46 mpg / 51 mpg
Manual: 607.2 mi. / 673.2 mi.
44 mpg is an extremely impressive number, look at how close that would be to the #'s a honda hybrid gets. still not impossible, just unlikely.
Old Aug 6, 2005 | 01:06 AM
  #39
fonseca's Avatar
I still average 32 mpg for a mix of city and interstate driving, and that's despite flooring it all over the place. I think that my intake/exhaust play a big part in the economy. Few people here have identical mods.
Also, someone who normally drives aggressively most of the time, and suddenly tries to be economical for a few tanks should not get results as good as someone who drives with fuel efficiency in mind most of the time, since our ECU adjusts itself to our driving habits. Those are probably reasons why people are reporting average MPGs so far apart. It's also normal for some cars off the line to get poor mpg, while others of the same model do better than they're rated for. Variability is expected even when the cars are brand new and supposedly identical.
I'd like to see someone getting terrible mileage reset their ECU and see if there is an improvement.
Old Aug 6, 2005 | 01:13 AM
  #40
zoned019's Avatar
Vehicle: 97 Tib
Do you guys top-off your tanks?
