Possible Intake Leak?
Old May 6, 2008 | 05:14 PM
cham's Avatar
Finally got rid of my o2 sensore CEL but then i scanned again and i got CEL P0441 02.gif makes me mad haha. But anyways i read up a bit could be an air leak, poped the hood, could hear a bit of a hissing noise near my manifol but im not sure which lines to check could soembody help me out with soem pictures of what lines to check for a leak?
Old May 6, 2008 | 05:48 PM
lol, if you think it's a vacuum leak, then check all of the lines comming from the intake manifold. The manifold generates the vacuum because the pistons pull the air faster then it can refill.
Old May 6, 2008 | 06:24 PM
'treezy's Avatar
no, that's the evaporative emissions control system purge valve code..
search for "evap" or "P0441" and you'll find a whole lotta stuff you may or may not want to know about the EVAP systems, ways to emilinate it, and ways to TS and correct your problem.
Old May 6, 2008 | 06:36 PM
cham's Avatar
yeah i know...i searched already im not that noob but yes i realize it could be a purge valve problem, but when i hear a hissing sound com from near the manifold makes me think its an air leak causing the code. I can't find any cracks
P0441 Evaporative emission (EVAP) system ��“ incorrect flow detected Hose connection(s), intake leak, EVAP canister purge valve
which makes me think its more of the intake leak than the purge valve problem but i can't seem to find any cracks or anything in any of my hoses by my intake but i can hear it
Old May 6, 2008 | 06:57 PM
lukeyn's Avatar
i have the same year and problem...
Old May 6, 2008 | 07:04 PM
cham's Avatar
if you fiugre soemthing out let me know...little off topic but that looks like a kaption sub in youre pic:O
Old May 6, 2008 | 08:53 PM
or discovering to --- get ready for this --- "leave it the ____ alone!!!!!!!!"
i think your purge might require cleaning. try that, it's free.
Old May 6, 2008 | 09:14 PM
Even if its not the problem, if you hear a leak fix that first. Take brakleen and spray it at hoses. When the idle changes a little bit then focus on that line or connection. Or take it somewhere to get smoked but the brakleen works just fine.
Old May 6, 2008 | 09:59 PM
lukeyn's Avatar
never heard of kaption...its a pioneer premeir spl competition twelve....awesome sound
back on subject...im getting the purge valve from a local yard and if that works you might want to try it out/ in other threads on the site...people have replaced it and the problem went away/
Old May 8, 2008 | 07:34 AM
lukeyn's Avatar
purge valve took away the cel....i tested mine by taking it off and blowing into it, and if it passes air uncharged its bad.
