P0441
Old Oct 26, 2007 | 08:03 PM
there is no other solenoid, the only thing that goes into the engine bay are the gas line that goes into the intake and the purge.
you mean the purge could be a problem? i wish i knew how the 2000 spec worked, but you can always check in a 97 by unplugging the tube and seeing if it's sucking air in, but i doubt you even want to mess with it and i don't know where it's located on a 2000.
Old Oct 27, 2007 | 10:57 AM
alpineboarder's Avatar
Vehicle: 1999 Hyundai Elantra
Most likely it's the purge valve. That code is specific in what is wrong. I had to do this earlier.
Old Sep 17, 2008 | 11:18 PM
Maverick's Avatar
Vehicle: 2011 Sonata Turbo
i got a cell and it's P0441 to .... when i go fill up the car it's really hard to start when the tank is full sad.gif
Old Sep 18, 2008 | 04:15 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
Specifically for your issue replace the solenoid in the engine bay. Your not venting to the canister when you fill up your venting to the engine basically flooding it with gas fumes.
Old Sep 18, 2008 | 07:55 AM
Rixshark's Avatar
P0441 Evaporative emission (EVAP) system ��“ incorrect flow detected Hose connection(s), intake leak, EVAP canister purge valve
Just a little offtopic.gif , but I thought I should say this...
Old Sep 18, 2008 | 11:06 AM
the evap for the 1998-2001 tiburons are in the rear next to next to the gas tank reachable from the driver's rear wheel well. it is covered by splash cover and bracket with two bolts. unscrew those two bolts and the evap system should be easy to inspect.
otherwise it's the purge that goes into the intake.
Old Aug 7, 2009 | 02:32 PM
guster900's Avatar
QUOTE (Bullfrog @ Sep 18 2008, 07:15 AM)
Where is this solenoid located in the engine bay? Any pics of it? Where could I order the part, what's it called? I'm having that problem as well.
Old Aug 7, 2009 | 02:50 PM
Look, I know you are new, but READ THE THREAD. There are several posts telling you where it is, and if you search for...
evap solenoid
You'll find tons more.
Please act like you've used der internets for more than 2 days.
Old Aug 7, 2009 | 03:13 PM
guster900's Avatar
So the solenoid in the engine bay, is the one next to the fuel filter? And the other one is on top of the carbon box in the back by the gas tank? are those the two solenoids? I didn't know if there was more then one solenoid in the engine bay that he could of been talking about.
Old Aug 7, 2009 | 06:22 PM
Bullfrog's Avatar
The one i had to replace was up by fuel filter.
