P0131 And P0135 Still Persist!
Old May 15, 2008 | 02:07 PM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
I'm going to trace the wires from the ECU to the connector, and then try to flip the wires.
Old May 15, 2008 | 02:17 PM
Just get under the car whereever you did your splicing of the wires before and switch the same color wires around.
Old May 15, 2008 | 03:46 PM
yamaha's Avatar
I switched both the white wires around, same thing happening. I also tried switching the black and grey for shits and giggles, same thing happens. I did unhook the primary oxygen sensor and the ODBII software was reading a constant .475. With the oxygen sensor plugged in, I was getting ups and downs betweek 0-.475. I tried both the old ECU and new one and same problem persists. I'm leaning towards a bad connector plug on the harness side. There is some slight damage, meaning the plug slides in to easy and the clip will not hold the molex plug from the oxygen sensor firmly. Thoughts?
Old May 15, 2008 | 04:05 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
You mentioned that you were going to swap the ECU from the Beta accent and see if the ECU is the culprit? how's that going?
Old May 15, 2008 | 04:06 PM
yamaha's Avatar
Did that, nothing.
Old May 15, 2008 | 04:19 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
check the continuity of the wires from one end to it's other end and see? if the ECU and o2 sensors swap did nothing, then it might be the wires
