Half-shaft Replacement
Old May 15, 2008 | 09:28 AM
aburgard's Avatar
I have to replace the half-shafts on my 2001 Tib. Do these require a core exchange? Has anyone found a decent online seller for them?
Also, my car has about 100,000 miles and the shocks/struts are out. Should I also be replacing the mounts? They good look so far.
Old May 15, 2008 | 10:38 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
As long as the mounts dont look dry rotted or are falling apart they should be good. If they look crappy or just want a piece of mind then replace them. I just did my shocks not to long ago and reused the mounts. That was at 75k
Old May 16, 2008 | 02:02 PM
Alex01tib's Avatar
The best place to find some driveshafts are at a junkyard. There are usually a ton to pick from so you can grab the one in the best shape.
You might want to pick up some replacement o-ring seals from dealer for like 3 bucks to avoid any leakage due to worn rings.
