O2 spoof.
I have a US 2002 Elantra GLS. I am looking for an O2 spoof "for offroad use only". Anyone know where I can find one or if one designed for a different car will work? Thanks for any replies.
I found this doing a search but it does not look like it will work as there are too many wires. The O2 sensor on my car has 1 wire. Still, any help would be appreciated.
http://casperselectronics.com/cgi-local/st...product=IMPORTS
Actually there is not enough wires. If your sensor is the same as the Tibs, then you should have 4 wires. They are heated sensors with:
1. o2 signal
2. ground
3. heater
4. fuel relay
You may not need the fourth for the fuel relay
1. o2 signal
2. ground
3. heater
4. fuel relay
In fact both hyundai (front and rear) O2 sensor uses 4 wires...
02 signal
02 ground
12 volts for heather (what some call fuel relay)
heather ground
Denis
02 signal
02 ground
heather ground
Denis
Guest
Posts: n/a
I have an O2 simulator made by Casper Electronics which is avail from Summit Racing, but have yet to get it to work on my 2001 elantra. I keep getting heater malfuctions with it. And yes the 2001+ elantra's have 4 wires on 3 that are in use for the #2 O2 sensor which is where you need to hook it up. The one that is not in use is the fuel relay which is used in the #1 O2 sensor only for fuel trim. Why they hooked up 4 wires on the #2 O2 sensor I have no clue. Also what wire colors are what on this thing. Maybe I had it AFU when i wired it the first 5 or 6 times lol.
