Now I cant decide for what buy!!! help!
Old Feb 13, 2005 | 03:24 PM
sharkev's Avatar
but where I can find if the 1.8L is going to be a wast??....
a few people says that is ok for both.... and like you say that is not so good for turbo....
now I dont know...lol.....
Old Feb 13, 2005 | 03:25 PM
UltraTibby's Avatar
Wow you guys post fast, check out my post above I edited it.
Old Feb 13, 2005 | 03:29 PM
sharkev's Avatar
I just saw!.... but how can you tell that if is a overlap or not??!... i dont understand that...
and finally is woth it to buy a 1.8L for a turbo or not??
what do you think??
real fast poster are here!...
Old Feb 13, 2005 | 03:34 PM
UltraTibby's Avatar
Alright let me explain.
On a stock 2.0L the intake opens at 8 degrees and closes at 40. Now on the exhaust it opens at 50 and closes at 10. That means that between the 8 and 10 degree mark you will have a flow through effect happening. With the 1.8L cam in a 2.0L it will change this opening to 4 degrees instead of the otherwise 2.
Old Feb 13, 2005 | 04:48 PM
sharkev's Avatar
I see.... but so its not so good this cam for a turbo setup ´cause the overlap... is better the stock one, right?...
Or is good in sort kind of way too..??....
I dont know what to do...............
Old Feb 13, 2005 | 06:19 PM
CyberShark's Avatar
you could always buy the 1.8 while you're N/A and if you decide to go turbo and dont' want the cam in there, you can always sell it on the side...believe me someone here will buy it..
Old Feb 13, 2005 | 06:25 PM
UltraTibby's Avatar
Alright well I am going turbod soon and have the 1.8l cam. This is about halfway on topic lol. Should I take it outa there?
Old Feb 13, 2005 | 06:31 PM
CyberShark's Avatar
Old Feb 13, 2005 | 06:42 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Yeah, it's prolly best unless you start messing with the pistons/compression ratio. Right now the best thing to do is to use the stock cams.
Old Feb 13, 2005 | 06:50 PM
UltraTibby's Avatar
But for the extra 2 degrees they are open together rather than 2 on the stock you still get 6 degress more open time on the high end. They would have to ballence out right?
