Monster tach
Old May 8, 2002 | 03:48 AM
  #21
wit2003's Avatar
Yea i read the whole topic and was pretty sure thats what i had to do but just wanted to double check so that i didnt waste any time. Thanks alot
Old May 8, 2002 | 03:57 AM
  #22
JAWS 021's Avatar
let us know the results
also remember which wire
thanx
Old May 8, 2002 | 04:10 AM
  #23
paul2k's Avatar
all u need to do is buy a tach that can read 2cyl!! VDO makes a few with a shiftlight. To tap into the oem tach signal, u remove ur gauge cluster, look at the back of the tach, and tap into the wire. i have done this myself and took me 10 min. I did it to an accent L that had no tach(the tach signal is behind the temp gauge harness, second wire from right) Do not tap into ur ecu, there is a higher chance of messing somthing up.
Old May 8, 2002 | 08:03 AM
  #24
wit2003's Avatar
Well i pliced into the blue ire with the yellow stripe and everything seems to work fine, except for the fact that the needle is kinda shaky and also it seems like sometimes the aftermarket tach cant reach 4000 rpm. I am gonna drive it around for a bit and see how it is. I'll keep ya posted.
Old May 9, 2002 | 09:25 AM
  #25
wit2003's Avatar
ok this is going to go out to all the people with tachs, what wires did you clip on the back of the monster tach, and what did you connect the others one too, which wires, mine wont go over 4k rpm
Old May 9, 2002 | 10:43 AM
  #26
JAWS 021's Avatar
im guessing neither wire worked
DAM!
scratch that theory
did you set it for an 8cyl?
Old May 9, 2002 | 01:14 PM
  #27
wit2003's Avatar
HEres the deal. I wired it to the blue wire with the yellow stripe. It idles right and matches the rpms correctly but sometimes when it gets around 4k the needle jumps back down to around 3k and kinda bounces. i have only clipped the brown wire and reattached the blue wire running it as a 2 pulse. After talking to Autometer they told me to clip both the brown and blue but when i did the aftermarket tach read that it was iding around 3k which is not correct. I hope that i dont have to switch wires cause i have already spliced into the blue one but if i have to then i will.
Old May 9, 2002 | 01:31 PM
  #28
indobird's Avatar
You're only reading half. Tap it into the ecu.
Old May 9, 2002 | 01:44 PM
  #29
wit2003's Avatar
How could i be reading half if they match at idle and pretty much all the way up to about 4k. It only seems to sputter a little. Takin all suggestions though. Thanks
Old May 9, 2002 | 10:19 PM
  #30
CatchUp's Avatar
I Still havent had time to work on fixing my gauge, i got 4 point racing seatsbelts i need to put in. I'm gonna try to fix the tach in a couple days, let me know actually works man
