Measuring Shaft End-play
Old Apr 6, 2008 | 11:28 PM
bryfx's Avatar
transmission rebuild is almost complete, but I'm kinda stuck on the following.
According to the shop manual and hmaservice, the end-play of the input shaft, output shaft and diff are measured using solder (or plastigage).
http://www.hmaservice.com/viewer/content.a...19077%5Eshop%24
Step 16, it doesnt actually show where to measure the end-play.
Question is:
Do I
A) measure end-play between the back of the outer race and the tranny case where the actual shim goes (or opposite end of shaft, clutch housing side)
or
B) measure end-play between inside of outer race and the roller bearings
Thanks!
