Manual Tranny Fluid
Old Dec 28, 2006 | 09:39 PM
  #21
fonseca's Avatar
The Syncromesh is definitely safe for our tranny, but it's designed for GM and meets their specifications instead of GL ratings.
They probably recommend this instead.
Old Jan 5, 2007 | 07:04 AM
  #22
Korean_Redneck's Avatar
Vehicle: 1999/Hyundai/Tiburon
QUOTE (fonseca @ Dec 25 2006, 07:41 PM)
Choose carefully. Amsoil SG gear oil is NOT safe for the yellow metals in our synchronized trannies, for instance. Other Amsoil products may work (Series 2000?), but no one carried them in my area, and I really dislike the infomercial-like Amsoil marketing, so I didn't want to run it anyway. Most GL-5 gear oils have sulphur and/or phosphorous additives which we can't use. Mobil1 LS is GL-5 rated and CANNOT be used either. I got that straight from the Mobil1 1-800 customer support number, since I see so much conflicting information about whether it can be used. Call them yourself.
Unless it's multi-rated, don't chance it. By the time you notice a problem, it will be too late. If it is multi-rated, it will say so on the bottle.
Penzoil Syncromesh is a good one and widely available. I love Royal Purple; when I switched to it I noticed a huge improvement in shifting smoothness. One reason I moved away from Redline is that no one carries it in my area, so I would have to order online if I needed to top it off or change it. That's reason enough for me when other good alternatives are locally available. I don't think switching from RP will provide an improvement based on my experiences with different gear oils, but flushing out your tranny and putting in fresh oil might help. I drained mine after just one year, and it was pretty contaminated.
Amsoil MTG and Amsoil SVG are totally different types of oil. Amsoil MTG is a must use for our cars. I recommend every Hyundai Tiburon owner to use this oil. They should avoid all other oils except Redline MT-90.
Old Dec 10, 2007 | 07:51 PM
  #23
Bullfrog's Avatar
Vehicle: 2001 Tiburon
I just changed tranny oil and put in Royal Purple and noticed that shifting has become very smooth. Im lucky and may change it this spring again as the drained fluid wasn't all appealing. So far I like it.
Old Dec 10, 2007 | 08:17 PM
  #24
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
I changed mine to Royal Purple a while back as well, but saw no difference whatsoever.. and god knows there's room for improvement, my tranny shifts pretty hard and awkward (even with kjb delrin bushings and ark sts). and 2nd gear synchro sucks balls
Old Dec 10, 2007 | 09:39 PM
  #25
LNHeart's Avatar
I got royal purple and swapped to a beta 2 tranny with kjb's derling bushings and b&m sts, i love the feeling of the shifts now.
