MAF / MAP
Old Nov 19, 2001 | 02:01 AM
Iago's Avatar
Default MAF / MAP
Two questions...one of which is bipartite.
1a) Can the stock MAFS be used in any size diameter tube, or must it be used ONLY in an enclosure of the stock size (2" ID, it looked like)?
1b) If the answer to the above question is "no, it must be used in the stock tube," are there any aftermarket MAFS's available with a larger diameter (ideally 3" ID)?
2) What are the requirements (aside from an appropriate ECU) to swap over to a MAP sensor?
