TPS Values
I got my ODBII software all set up! It's SWANK.
Upon tinkering around with the various readins it makes, I noticed that, at idle, my TPS is reading that the throttle is open 14 degrees. Is this about right, or do I have some serious readjusting to do? I wasn't able to do a full-throttle run yet, so I don't know if or how early it opens to 90 degrees (full open), but 14 at idle seemed a little high. I would have figured that, at idle, the throttle should be fully closed and the engine is running on air going through the throttle bypass tube...
