Lsd's What Is Needed
It seems to be accurate. Im still trying to kind of piece it all together but it sounds good. Im going to go on my DSM forum and post up about this.
From searching the other quaife thread I posted at the top I found its the FWD turbo differential we need. It wouldnt be the non turbo because that uses the neon 420A motor and wouldnt have any compatibility with ours. We also need the 25 spline which should be noted to check with the original parts off the other cars
If I had one I could check for sure with my spare diff. Just put in my quaife but I will have a spare trans again in a few weeks or so depending on when I can finally meet up with Lilo.
this is the first time I saw the thread, but now I want to try it, I have a spare trans to swap in so it's perfect timing. Redz, I looked on ebay and couldn't find any oem ones today, maybe I'm just dysfunctional.
I think I did a search for mitsubishi lsd and looked through them. There were at least 2 OEM ones and a used KAAZ Helical 2 way.
kaaz lsd
This one looks almost 100% like it will work. That is the speedo ring I am using with my Quaife and based off of pictures that will work. Not sure if I could sell the manual trans with lsd in it for enough to get money out of the diff and my spare trans though. hmmmm
