Koyo Performance Rad Fitment
REDZ!
I think the upper rad hose was off by about 1/2 inch but nothing that didnt fit.Some miner cutting of the rad hose and it fits.
All you do is cut the bend where it connects to the inlet of tha Upper Rad hose and then you insert ...........VERY SIMPLE...........Other than that fits NO problems and drops right in.
The FAL fans will work perfect as i have mine installed without any issues smile.gif
Vehicle: 01 Tiburon
yeah...
2 uniq, it looks like you have used the "through-rad" mounts (zip tie thingies) for the fans...
we wanna know if you could've used of is there a way to us the "real" mounts on the mounting points both the fan and the rad.
yeah...
Im not sure if you can use the mounts that come with it ..............ZIp thingy will do fing02.gif
It looks like the upper mount is bent upwards in this pic?
http://memimage.cardomain.net/member_image...37_314_full.jpg
Jay-M, I'll give it a shot when I get mine. I kept my mounts.
And it looks like Jon is right. Maybe a spacer would fix that?
Or someone else said (Madjohn), that you could use the GK mounts.
Personally, I would get a 1" strip of 1/8" polished aluminum. Bend it in a vise to shape the curve, then round out the ends and drill the holes. fing02.gif
Making shit yourself>>>>>*
