Intake Question for Random
Old Apr 10, 2002 | 04:27 PM
Veniston's Avatar
Air temp low? That shouldn't happen unless you unplug the sensor. Maybe one of the wires got slighyl busted when you were moving it around? If you can get the codes read, you need to watch them--they'll narrow down where the exact problem is.
Old Apr 11, 2002 | 09:27 AM
dc1238's Avatar
well guys thanks for all the help i have found the problem....
this vac hose was before the MAF sensor and was lowering the air pressure in the pipe so low that the MAF wasnt getting the correct reading.
in this pic you can see down low on the pipe the nipple that the vac was attached to. i just have to cap that off and the thing is runnin great again
