Increase Fuel Economy By 15% In A Weekend!
Old Jun 5, 2009 | 03:37 PM
supercow's Avatar
^^if their are any spots oh high resistence then it would help. I missed the ground on top of the transmission on time. When I hooked it up there was a noticeable difference! Probably only .5 hp though.
Old Jun 5, 2009 | 03:40 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Why bother with a manual swap when you can just put a magnet on your fuel line, a turbonator in the intake and a hydrolysis system under the hood and get 900mpg?
Old Jun 5, 2009 | 03:59 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
QUOTE (Stocker @ Jun 5 2009, 08:41 AM)
O2 sensor performance. Nevermind.
I don't think O2 sensors ground through the exhaust, the harness comes with a ground for the heating circuit as well as a ground for the signal (4 wires)
Old Jun 5, 2009 | 04:15 PM
frozen's Avatar
Vehicle: 2001 Tiburon
Radu is correct, there is a seperate sensor ground wire. It wouldn't be a good idea to ground through the exhaust because once the gaskets and flanges rust, they increase in resistance which would throw your sensors off.
Old Jun 5, 2009 | 04:34 PM
Then what's the point again of grounding the exhaust? It's not an elex. component!
