I Need A Dedicated Tuning Os.
Old Jul 11, 2010 | 10:24 PM
  #41
^^ Those binary arrays drive the online status monitoring tests. The information which comes afterwards is the important stuff. I had the log level set up too high. Level 3 = binary, level 2= communications Level 1 = this:
CODE
coolantTemp=51.0C
coolantTemp=83.0F
Long Term Fuel Trim Bank 1:6.0
RPM: 3608.0
MPH: 0.0
KPH: 0.0
Timing Advance degrees: 9.0
IAT: 36.0C
IAT: 68.0F
MAF: 5.0 Gallons Per Second
Throttle Position: 12.0%
Found O2 sensor 1 at Bank 1
Found O2 sensor 2 at Bank 1
O2 Sensor Bank 1 Sensor 1 Voltage: 0.14
O2 Sensor Bank 1 Sensor 1 Percent: 3.0
O2 Sensor Bank 1 Sensor 2 Voltage: 0.47500000000000003
O2 Sensor Bank 1 Sensor 2 Percent:0.0
CLOSED LOOP-Using O2 feedback for A/F Ratio
CheckEngineLight:ON
NumberOfDiagnosticCodes:2
Misfire status:Test Complete
Fuel System status:Test Complete
Components status:Test Complete
Reserved status:Test Not Available
Catalyst status:Test Complete
Heated Catalyst status:Test Not Available
Evaporative status:Test Complete
Secondary Air System status:Test Not Available
Refrigerant status:Test Not Available
O2 Sensor status:Test Complete
O2 Sensor Heater status:Test Complete
EGR System status:Test Not Available
Fuel System Status:CLOSED LOOP-Using O2 feedback for A/F Ratio
Secondary Fuel System Status: Not Present
This is a full mode $01 scan from 1-20. Log level 1 presents it in a nice manner. Still working on perfecting things though. Seriously though, the gauges are not the hard part. The hard part will be making the entire display user customizable so each gauge is like a drag-n-drop widget with customizable backgrounds. I could easily slap a gauge up there from the javaFX collection.
Old Jul 12, 2010 | 02:22 PM
  #42
Oh, well when you put it that way, it's pretty nifty. Keep up the good work.
Old Jul 15, 2010 | 05:18 PM
  #43
Just to keep this updated, work has begun on the GUI. OBD2ner can now process data in an infinite loop. Car requests data>computer receives>computer sends>Car receives>Car Sends information and request> Computer processes and displays and sends more information. It's pretty beautiful. The program is working fully under USB and requires a special little helper script for Bluetooth OBD communiations on Linux. Now I just have to add the human intervention portion.
