Hyundai Fuel Injector Sizing.
Old Apr 7, 2005 | 03:59 PM
TiburonWao's Avatar
Beta 1 and Beta 2 has the same size injectors??? what about the cc's of the 2.7 Tuscani???
Old Apr 7, 2005 | 04:07 PM
I know that.
But he doesn't.
He said that all kits come with those. Out of the what, 3 or 4 kits available, one comes with them.
Old Apr 7, 2005 | 04:14 PM
albert's Avatar
No beta1 and beta2 do NOT Have the same size injectors... Read the posts above...
Old Apr 7, 2005 | 04:22 PM
I thought we had figured before that the Beta 2 injectors and some of the other OEM injectors don't fit the Beta 1 wiring harness, and don't fit on the fuelrail/runner ports.
Old Apr 7, 2005 | 04:35 PM
Shadohh's Avatar
Beta 2 are 190cc, this is proven, its stamped on them.
Beta1 has no markings. When random posts his sheet we will know they are 245cc ish.
Old Apr 7, 2005 | 09:20 PM
Casper's Avatar
I've got 4 1.8 injectors. Let me know if you need em to get them tested. I am 45 mins away from philly so I could literally hand them to you. I would like them back though smile.gif
Old Apr 7, 2005 | 11:12 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
I'm off topic here too, but I would love to know this info. There has been a bit of controversy over the Beta I injector sizes.
I was searching for this exact info 2 weeks ago. I came up with what Shaddoh/Random said, 245cc. But also read 190cc.
Shaddoh actually posted this on HP.com
"The stock Tiburon injectors are 245cc/min at 43psi High Impedence."
QUOTE (Denisst99 @ Mar 25 2005, 02:17 AM)
i've flowbenched 8 of them and they were in the 255-260 cc/min range
a bit more then the 247 cc/min that has been around for a while
And Denisst99 posted this in a thread I created about Pulse Duration. Maybe someone can get Denisst99 to come up with a slip for the 255-260 numbers.
Old Apr 8, 2005 | 12:21 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
So if Beta1 and Beta2 injectors are different in cc, is it possible to swap between them?
Mustang 3.8 injectors and Sonata 2.4 injectors fit Beta1 or Beta2?
Old Apr 8, 2005 | 01:15 AM
albert's Avatar
I spoke with Red. His Revision A 2.0L Injectors were 245's...and that's what we all took as gospel. (hey, it's RED we're talking about here...)
But Jaws021's 99 2.0L Injectors tested out at 250cc. (I had it backwards in the previous post).
Both readings are at 43psi of fuel pressure.
