HKS Dual Dragger
Old Aug 24, 2001 | 04:14 AM
Iago's Avatar
Default HKS Dual Dragger
Anyone know if I can hook one of these bad boys onto my Tib? I see that it's a double-muffler, but can the pipes heading into those come from a single pipe with a splitter? Would this work, or will it only make it sound underpowered and weak?
I really like the look of this setup, and would greatly prefer to have the double-tip outlet over one large single-tip coffee can. I don't care about LOUD output; I'm looking mainly for performance and a full subtle tone.
Old Aug 24, 2001 | 06:00 AM
They come with a single inlet that splits to 2 outlets.
Old Aug 24, 2001 | 06:09 AM
Iago's Avatar
Random, I know you used to have a Dragger of some sort. Was it a single-out or a dual-out? How'd you like the quality of the product / fit / installation / etc?
Old Aug 24, 2001 | 07:32 AM
I had the normal HKS Dragger. It was ligher than the stock exhaust and much higher quality. A tad noiser than stock, but nothing horrible.
It was a decent item as far as mufflers go.
Old Aug 27, 2001 | 05:35 AM
Iago's Avatar
I plan on eventually turbocharging my car, but I wouldn't mind picking up the exhaust first. I'd like to save on re-doing any work, so if it's possible, I'd put on the 3" exhaust piping that I'd eventually need for the turbo. But, before I turbo, since I still need a little backpressure, is there any sort of temporary restriction I can put in that will keep things running right? I'm not going to blow any money on headers (again, since I'm going to boost), so those would remain stock. Would those alone, with their smaller diameter, provide enough backpressure to keep my low-end torque? If not, would some sort of small restriction, like a reducer from 3" to 2.25" followed immediately with another reducer put in backwards that would open back up from 2.25" to 3" work? Or should I just hold off on this pipe dream (pun very much intended) and do it all at once when I go boost?
