Flywheel Suggestions?
Old Oct 7, 2008 | 05:31 AM
I'm pretty rough on my clutch/flywheel. I think it's warped. I keep slipping it to get more torque. I need a flywheel that can keep up to my demands. I need a better flywheel. Any suggestions as to a resilliant flywheel? I'm looking to spend about $100-$200
Old Oct 7, 2008 | 11:28 AM
I think you can get the chromoly one for about that. Otherwise budget a little more for the Fidanza. Thats about it in our flywheel options.
Old Oct 10, 2008 | 06:53 PM
That chromoly looks like the stocker. What's the difference?
I'm looking at this one http://cgi.ebay.com/ebaymotors/XTD-PROLITE...emZ350108371036
I've heard nothing but good things about XTD, but these are people who change their clutch on the weekends for fun. Will it last? I'm looking for something that I can beat the hell out of for at least 60-80,000 miles.
This one looks GREAT http://cgi.ebay.com/ebaymotors/HYUNDAI-TIB...itemZ7986976803
I havn't heard anything about it. I know some do not like clutchmasters, but this can't be bad. Look at all of the cooling area. Flywheels dont shatter do they?
Any other suggestions? I'm going to lay down some money for it this weekend. I don't want it to be a bad buy. Please give me some good suggestions.
Old Oct 10, 2008 | 08:08 PM
I heard my name!
Helz yeah clutches shatter! A guy at my work had a car totalled. Dodge stealth "just driving along" on the highway and "BAM!" ::STOP!::
Cracks worked their way all the way across the flywheel and sent chunks out at engine speed. Like 7lbs chunks of steel. Killed:
Flywheel (duh)
Clutch
Pressure plate
Bellhousing/Trans
Side of engine
Radiator
Wiring harness
And that was all she wrote for that car.
Old Oct 10, 2008 | 09:45 PM
no shit clutches shatter. I said flywheel guy.
QUOTE (DTN @ Oct 10 2008, 08:53 PM)
Old Oct 10, 2008 | 09:49 PM
dddude55's Avatar
Vehicle: 2011 Kawasaki ZX6R
Did you read that part?
Old Oct 10, 2008 | 10:48 PM
Coal_forge's Avatar
I will haunt you if you get an aluminium flywheel. The honda-tech people have had luck with the ebay special steel flywheels (like f1).
Old Oct 10, 2008 | 11:17 PM
Thanks dddude55, yes I meant flywheels.
He brought in the biggest chunk of flywheel and it was bigger than my palm.
That's one lucky driver. If that piece of steel had headed for the firewall he'd have been in bad shape.
Old Oct 10, 2008 | 11:34 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
QUOTE (Coal_forge @ Oct 10 2008, 09:48 PM)
Why dat? I've had a Jim Wolf aluminum flywheel in my Z for over a year and no problems.
Old Oct 11, 2008 | 06:58 AM
QUOTE (dddude55 @ Oct 10 2008, 11:49 PM)
Yeah, I took it as he was saying the clutch broke and it broke everything else. Makes sence now
QUOTE (Coal_forge @ Oct 11 2008, 12:48 AM)
What is involved in this haunting? What's wrong with aluminum? It dissipates heat quickly right?
QUOTE (eclutchmaster)
Because a 11lbs eClutchmaster light weight flywheel® has so much less rotating inertia than the stock 22-25lbs stock flywheel., it is easier on your synchros. When you downshift and do not perfectly equalize revs, your synchros must accommodate the difference in flywheel speed and input transmission speed. The lighter the flywheel the less the inertia the synchros must overcome. The longer your synchros last the longer your tranny will last because you are less likely to miss-shift and break things when your synchros are properly functioning.
Engine life is also increased by using a eClutchmaster aluminum flywheel®. Since our flywheel is so much lighter there is much less stress on the main bearings.
