Check Engine Light On
Old Jan 5, 2006 | 07:12 AM
Tibracer33's Avatar
Vehicle: 2001/hyundai/tiburon
My check engine light is on because the O2 sensor that is suppose to be in the headers isn't there, and I have been told that once I put it there it will go off.
Old Jan 5, 2006 | 09:06 AM
QUOTE (NightShark @ Jan 4 2006, 11:21 PM)
na we really don't.. unless its some private garage that will do it.. but any chain shops like autozone in your area wont have that down here..
Yeah you do, we've found them up there before.
Go around and call every auto shop in your area.
If that's too time consuming, go buy a scanner from Wal Mart or some other store and return it when you are done using it.
Old Jan 5, 2006 | 01:58 PM
shortyg83's Avatar
No after market headers did install cold air in tak but that was about a month ago
Old Jan 5, 2006 | 06:38 PM
tb1198's Avatar
go get it scanned......no one here is psychic
Old Jan 5, 2006 | 08:34 PM
if that's the last thing you did, i'd check that AIT sensor on the CAI. It tends to get pulled a bit. it happened to me and caused a CEL. So i lengthened the wires. I havn't had a problem since. Remeber that the tiburon takes 2 times being turned on and off (drive cycles) to realize there's a fault. IE. turn on car, fault, turn off car, turn on car, fault, check engine light. think back, maybe you hit a bigassed pothole?
sometimes the O2 sensors will make the check engine light go off and if anybody reading this can verify that info it would be much appreciated because mine is on too and all i did was put my headers in
from what i've read you have to do the sensor relocation on the RD2 tiburon or it will throw a CEL because the catalytic converter is on the downpipe.
