Can I use the kit Alpine without UNICHIP?
Old Oct 23, 2001 | 04:33 AM
Franz's Avatar
Vehicle: 2008 Accent
Default Can I use the kit Alpine without UNICHIP?
My Tiburon is 1.8L and it isn`t MAF system.
I have fuel pump walbro high pressure.
I have inyectors of 550cc.
I have kit TC alpine.
Can I use my car without instaler the unichip and without the 5to inyector??????
What things have I to do for that my car is correctly?? thank for your help!
Old Oct 23, 2001 | 07:43 AM
The uni-chip can be tuned for MAF or MAP. The uni-chip can run 4 larger injectors or 4 stock injectors and a 5th one.
I would RECCOMEND that you go with the 4 larger injectors. The only problem you MIGHT run into is that I am not sure if the stock Hyundai MAP sensor likes seeing positive pressure. A CEL might be triggered by the pressure in the Intake Manifold (boost). You might have to swap out that sensor, or the Uni-chip might do a great job of compensating for it, I just don't know.
Alpine should have send you a Uni-Chip programmed for MAP, and should have sent you wiring instructions for a MAP equipped engine.
If they did not, you will have to contact them and have the send you the right uni-chip and right wiring instructions. South-African Tiburons are MAP equipped, so they can just send you one of their standard Uni-chip programs. However, make sure they know that you are using 4 larger injectors and not the stock units with 5th injector. They will have to alter the programming accordingly.
Old Oct 23, 2001 | 08:19 AM
You might want to read this... http://www.teamsr.org/cgi-bin/ultimatebb.c...c&f=16&t=000620
It seems the uni-chip will NOT work with 4 larger injectors, as it will not be able to cut the level of fuel enough to allow you to idle...
