cam shaft installation
Old Feb 13, 2002 | 12:26 PM
trigun tibby's Avatar
Default cam shaft installation
I just bought the GT cams, is the installation hard, or can it be done out of a shop, iif so, anyone know how to do the swap.......
Old Feb 13, 2002 | 01:46 PM
FordFasteRR's Avatar
get an experienced engine mechanic to do it for you, shouldnt charge more than 2-3 hours of labor at most.
some shops charge $40 an hour/ some charge more... either way, go to a reputable shop that has a warranty on their work, if they screw it up and the car runs like shiaat, then you can take it back and have them check the cam alignment...
if they install them right the first time, you shouldnt have any problem... also, if you decide to do it yourself, get a good torque wrench, and get a manual for the engine that shows the EXACT torque sequence for the cam bearings and the torque numbers for all the bolts....
