CAI vs. rain
Old Mar 2, 2002 | 10:03 AM
NightRaven's Avatar
Default CAI vs. rain
Welp it's raining and my CAI has had it's first wet weather test. Results... Inside of fenderwell is wet.. Now should i get a bypass or is the amount of water that got in alright?
Old Mar 2, 2002 | 10:22 AM
ammoman's Avatar
You'd have to immerse the entire filter in a bucket of water and gun the engine before you have to worry about hydro-lock.
Okay, that's a little extreme, but you have nothing to worry about. Does your filter sit in the fenderwell above/behind the stock plastic weatherguards (a-la Random Special), or is it hanging like one of the production intakes?
Old Mar 2, 2002 | 10:24 AM
Bad Shark's Avatar
Vehicle: 2000 Tib
you'lkl be fine as long as the waters not deep....just cuz its wet out dont mean its gonna be a problem...
but yeah get the BPV soon wink
Old Mar 2, 2002 | 11:25 AM
NightRaven's Avatar
ammoman:
it's a random special with it in the fender well. engine shield has an extra hole in it (got careless due to sun setting) and theres a gap between the engine shield and the fenderwell nose cover.. not 100% sure how wet it was, i reached up underneith and rubed my fingers around and they came out with water on them... so to actualy cause a problem i'd have to dunk 1/2 the filter into a puddle right?
Old Mar 2, 2002 | 12:10 PM
No. You would have to dunk the ENTIRE filter underwater, and more than that, the entire filter would have to be submerged long enough for the engine to suck water up a 2.5+ inch diameter pipe 2-3 feet long. This isn't much time, but the likelyhood of it happening is VERY slim. The sort of conditions that would cause this to happen, are the kind of conditions that you should not be driving in. Constant driving through water up to the middle of your wheels is stupid, eh? The occasional puddle, even a deep one as long as it is shallow enough to drive out the other side without getting water in under the doors, WILL NOT hydrolock your engine.
...unless God hates you, which is unlikely.
Old Mar 2, 2002 | 12:18 PM
NightRaven's Avatar
thanks big time... was a tad spooked about it all and it woulda been a ***** to re cut and fit to include a bypass valve.
Old Mar 2, 2002 | 12:56 PM
Elantra151's Avatar
thts good to know
Old Mar 2, 2002 | 04:00 PM
FordFasteRR's Avatar
i had a problem with a cold air intake on my highschool car... a 94 nissan sentra... i got in a deep puddle, for just a second.. i didnt mess up the engine ,but i fried the air flow meter sad.gif
the dealer was the only one i could turn to and they raped me for a grand total of $360 for a new one including labor.
.. that was then, this is now... i use a short intake. 1-5 extra HP isnt worth it anyway. hehehehe
Old Mar 3, 2002 | 02:05 AM
ammoman's Avatar
There shouldn't be a problem with your intake and water. I've had my Random special on for over a year, never any difficulties caused by water. The only downside is the crappy APC filter I've got on the end of it, but a dry paint brush usually fixes that. One of these days I'll get around to putting a better filter on.
Glad we could be of some help.
Old Mar 3, 2002 | 08:17 AM
ammoman:
What is wrong with your filter that a paint brush fixes?????
