Box intake manifold project and discussion
Old Apr 5, 2011 | 11:33 PM
  #51
Looks pretty great.
Old Apr 6, 2011 | 08:27 AM
  #52
turbosocks's Avatar
looks very nice!! lets hope it performs as well!!
great job!
Old Apr 6, 2011 | 05:23 PM
  #53
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
Originally Posted by supercow
wow, very nice clean install. I like!
Might have to steal some of your ideas.....
where'd you get the fittings for water for the turbo? Any how did you get it without cutting the hose? just wiggle a piece of threaded pipe in, drill a hole for the fitting, and clamp around it for water tight seal?
Its a kit from Jattus Performance, there is a tap that goes inside the hose with as you mentioned a threaded fitting on the end. A seam has to be welded around the end of each tap though or the hose will blow off under pressure. My hose is cut very straight and I notched around the fitting so I was able to squeeze both parts back together without a gap.
Originally Posted by Mr. Muffin
whats it gonna rev to?
edit: got pics of the inside?
I have to take it back off to have the manifold flange leveled since it warped a little bit during the welding process, when I get it done there will be pics. It was put back on so I could put all the sensors in location and clean up or shorten wires as needed behind the dash.
