Beta II head on Beta I engine, any gotchas?
Old May 12, 2012 | 03:16 PM
bigfishmoney's Avatar
BETA I head will fit on BETA II head NP
I would VIN for correct intake cams though cause it could be 2.0 or 1.8 but i do not think it matters 1.8 is what it is though
but dont put 2.0 cams on a 1.8 engine
everything is the same
Old May 13, 2012 | 08:55 AM
everything is the same other then the thermostat housing and intake. should be a simple swap in a night
Old May 13, 2012 | 12:17 PM
you forgot the oil restrictor on the block and the different cam sensor but yes
it bolts right on
im rockin one right now
Old May 13, 2012 | 10:40 PM
oh one beta head differs from the other in that 1 of the heads have 2 thermostat related sensors, and anothers only got 1 figure that out and u will have a lot of information about the type of cylinder you have
Old May 19, 2017 | 05:19 PM
427troy's Avatar
Vehicle: magqualaVE
Someone said one can swap Beta 2 intake cam into a Beta 1 head. Swap the lifters too, and have one solid and one hydrolic cam? The engines have different lifters, so swaping ONLY the cam will NOT work.
Please advise.
Old May 20, 2017 | 12:03 PM
rob40's Avatar
Vehicle: 2000/Hyundai/Coupe F2 Evo
Please advise.
Just swapping the cam works very well and many have done it, i think the valves are different lengths between the 1 and 2 so lifters can't be swapped
Old May 22, 2017 | 08:04 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
Remember you'll need to swap on your Beta 1 intake manifold. The intake ports on the head are pretty different but nothing a mild port job can't fix! Also is the head your getting already good to go meaning the cams are installed? One pain you get from the switch is you'll have to periodically check the valve lash. Its a VERY tedious job and requires lots of shims of different thicknesses.
Old Oct 9, 2018 | 07:24 PM
427troy's Avatar
Vehicle: magqualaVE
Wink Valve length, hydraulic vs Solid
rob40,
You are correct that the valves are different lengths. Cams do swap. 18 months later, my knowledge and experience with Beta engines has tripled. I don't know why anyone would put the loud solid lifters on a Beta 1 engine. The misery and cost of adjusting (coins are $28 ea) is enough alone. The hydraulic lifters are so much better. The Beta 1 makes more horsepower for a reason. - and a machinist told me that .010" - .050" can be removed from the base circle and the hydraulic lifters will fill the gap. I'm going to research more, but that's my plan. Oregon Cam Grinders will regrind a cam for $100+-
et al., I missed third gear in a drag race and hit first. My Beta 1 did at least 10,000 maybe 12.000 RPM for an instant, and still ran for 2 months before it seized. Powdered metal rods are awesome!
Old Oct 12, 2018 | 12:08 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
The main reason people in Puerto Rico go with Beta II solid lifters is because you can use higher cams with solid lifters.
Related Topics
Thread
Forum
Replies
Last Post
rob40
Hyundai Tiburon Forum
21
Oct 11, 2016 04:04 PM
2000J25SP
Engine, Intake, Exhaust
2
Dec 28, 2015 11:22 AM
dude2111
Hyundai Hybrids
16
Aug 22, 2012 02:37 AM
SpoolinShark
Wanted
1
Feb 20, 2012 10:56 AM
SpoolinShark
4
Jan 28, 2011 01:59 PM
