Best Cat-back
Old Feb 19, 2002 | 05:30 AM
croat's Avatar
Default Best Cat-back
Well, after some more recent posts, I need an anwser.
For a 2001 Tiburon (2.0 DOHC) 5 speed, whats the best Cat-back, this is also assumming the following modifications have been done:
AEM CAI
SR Barney TB
Extrude Honed Intake manifold
HVE Ceramic Coated Header
2.5" Random Tech. free flow cat
Fizanda Flywheel
Kore Stage 3 clutch
(this modification list is tenative)
[ February 19, 2002: Message edited by: croat ]
Old Feb 20, 2002 | 12:20 AM
Decker's Avatar
toss up between Speedstate MBRP catback and kore's catback.
Old Feb 20, 2002 | 03:19 AM
croat's Avatar
Well random, with those mods is it better to run a 2.25" free flow cat with a 2.25" catback, or a 2.5" free flow cat with a 2.5" cat-back?
Thats the question I need awnsered.
Isnt the HVE ceramic coated header a 2.5" diametere where it meets the cat?
Old Feb 20, 2002 | 04:11 AM
JAWS 021's Avatar
use a high flow cat
dont use free flow cats
1 free flow cat emits the same pollution levels as 100 stock or high flow cats
plus,... YOU WILL get a check engine light
get a high flow cat
car sound is the best
if you have a 5 speed go with a 2.5 exhaust all around 4-1 headers, 2.5 high flow cat, and 2.5 catback
if you have an autotragic,... get a 2.25 all around
i believe HVE headers are 2.5
Old Feb 20, 2002 | 04:19 AM
SilverTibby's Avatar
What is free flow CAT?
Is that fake CAT look-like thing?
Old Feb 20, 2002 | 04:27 AM
JAWS 021's Avatar
a free flow cat is a cat that has been hollowed out
everything that usually cleans out pollution is removed
so the car spits out raw pollution that has not been filtered
performance wise, it does help.
But,... if you ever have to pass a smog check,... you will NEVER pass
just get a high flow cat
you get filtering and performance
do it the right way
Old Feb 20, 2002 | 05:08 AM
Brendan's Avatar
Best cat back is a custom made one smile.gif yes hi flow cat not free flow, plus if you use a free flow you will loose some low end and it you don't have a super or turbo and use 2.5" you will get stagnant air in the exuast, ie loose power.
