air intake rubber connectors
does anyone know where i can get those intake connectors the rubber ones. im building a cold air intake and i cant seem to find any conectors for the tubing to conect to the throttle body and then to connect the tube to the maf sensor any help would be appreciated thanks
Hook up.
www.thermalflex.com
Douglas Scott
562-926-9090
The 2.5/3" reducer is $14.45
And the 2.5/2.75" reducer is $15.00.
Please call to order.
They come in fun colors.
[ September 07, 2001: Message edited by: Random ]
www.thermalflex.com
Douglas Scott
562-926-9090
ok guys i found the answer to my own question if you will settle for black connectors. thanks random but those are a little ont he expensive side. you can get the 3 to 2 inch reducer at lows in the pipe clamp section it come with the 2 clamps too for like 4 bucks. they also have the straight 3 to 3 or 2 to 2 basically any size rubber connectors you can think of and seem to be of good quality. just letting you know.
The hardware store connectors will work, but just make sure they are THICK rubber. When that rubber heats up it gets soft, and thin rubber can "collapse" when under suction (hard acceleration).
Also...that rubber is not meant for the heat in engine bays. Make SURE you keep an eye on it for cracking/melting/falling apart.
The Thermalflex hose is somewhat expensive, but that is Silocone hosing. It will last for YEARS.
yeah it gets soft when it heats up.
they are made from urethane or thats what it says on them.
they are fairly thick
thicker than i thought i would need.
thanks again ill keep an eye on them.
