About the 1.8 L cam
Hmmm... 5100RPM? Sounds a little low. I guess thats close if it's stock and then you swap to 1.8L. The AEM Intake dyno moves the peak power from 119whp@5300RPM to 124whp@5600RPM. The more n/a you go, the higher the RPM band moves. If its a fourth gear pull, most dynos are, with the AEM you would generally shift at about 5900 for best power. Anymore than that and torque falls through the floor. I never knew torque fell so much after 5000RPM.
