5 speed difficult to put into reverse gear?
there are NOoooooooooooooooooooooooooooooooooooooooooooooooo oooooo syncro in the reverse gear for the tiburon.. redz you are right that slowly bringthe clutch back will pop it in but to do it correctly is to put the car into first gear first..this will line all the gears up first .... then from first gear go to reverse.. you will find that there will be no grinding or hard time of puttin it in.. for those of you who cant find the hole...
Yup, you are right man. Clutch all the way in, put it in first then into Reverse.
If you can't find the hole, put a little hair above it.
LOL
LOL
Like Redzman said, the best way to deal with it is to double clutch: Fully press the clutch and then let it out. The press the clutch again and you shouldn't have any problems going into reverse. You can also try gently pushing the shifter into reverse while slowly releasing the clutch. It will work, but I get a little grinding this way so I rarely do this.
QUOTE (rockym20)
doesnt any one listen........?????? i swear this will turn out to be like vision and the 3rd gen lambo doors topic.. i swear it will..
Guest
Posts: n/a
I have a 2000 Tibu, i have encountered the same problem when trying to reverse. All you do is put it in first gear and drive it a little forward, and then try putting it in reverse, trust me it works all the time man...
Edward Spliff
El Paso, TX
Edward Spliff
El Paso, TX
I have the same problem w/ my 01 tib. I also sometimes havin trouble putting it into 1st and as far as reverse goes it acts like its there and it wont be. some times i have to put it into neutral and then push the cluth n again
