Wring Power Cable From Battery To Trunk.
Old Oct 9, 2005 | 05:14 PM
2pacalypse's Avatar
I can only see the first pic of the topic, why is that?
Old Oct 9, 2005 | 08:12 PM
long's Avatar
wow, thats kinda dangerous. make sure you put some wire loom on top of that wire. to much exposure.
i have mine running through the firewall. i just drilled a hole. a lot easier and safer.
Old Oct 15, 2005 | 11:28 AM
just found something out with everything out of my car. the spot where firebug ran his is good if you dont have a sunroof. if you do, you should have a long tube running from the sunroof to that spot, as a drain.
Old Oct 28, 2006 | 10:23 PM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
Anyone have the missing pictures to reupload for this?
Old Oct 29, 2006 | 12:27 AM
^^ in case you need help, you pull off the wheel well cover and run it through the grommet, then down along the driver's side baseboard, stuff it into the corner of the rear seat and then into the trunk.
Old Oct 29, 2006 | 09:07 PM
Vladimer's Avatar
Vehicle: 01 Tiburon SE
but like said... if you have a sunroof it aint gona work through there.
other solution is just taking the fender off (4 10mm bolts up top, 1 in the door and 1 nut behind the corner light, on an rd2 at least) and theres a big space of open area you can just grab the wire from the battery and poke the wire through the big wire grommet they have there to begin with and it ends up by your feet also
did it this way last time and must say... 1000000x easier then if you ever plan to drill through the firewall, did that the first time and wow... what a headache, and almost hit my brake booster too sad.gif
so if you dont got a sunroof, go through there, if you do, just take the fender off, itll make sense once you see it, takes like not even 5 min to remove if your going slow
edit: even managed to find an older picture of what i mean
Old Oct 29, 2006 | 09:19 PM
I drilled a hole in the passenger side floor right next to the steering actuator rod. I put a grommet in, ran my wire through the floor and then zip tied it to the stock wire looms on the firewall.
Old Oct 29, 2006 | 09:58 PM
xxxmonoxidechild's Avatar
<div class='quotetop'>QUOTE (Vladimer @ Oct 29 2006, 11:07 PM) <{POST_SNAPBACK}></div><div class='quotemain'>other solution is just taking the fender off (4 10mm bolts up top, 1 in the door and 1 nut behind the corner light, on an rd2 at least) and theres a big space of open area you can just grab the wire from the battery and poke the wire through the big wire grommet they have there to begin with and it ends up by your feet also
did it this way last time and must say... 1000000x easier then if you ever plan to drill through the firewall, did that the first time and wow... what a headache, and almost hit my brake booster too sad.gif</div>
even your way is alot harder then needed. thats how i installed my 0 gauge. a;; you need to do is pull off the inner fender, and u can reach everything you named. and not have to go through all the work of pulling the actual fender itself, and re alligning it afterwords.
Old Oct 29, 2006 | 10:08 PM
^^ u talking about the wheel well cover under the car?
Old Oct 29, 2006 | 10:21 PM
yea, ive allways heard it referred to as a inner fender, but wheel well cover would fit also. (the black plastic inside of your fender well wink1.gif )
