The New 1.8 Cam Install
Old Mar 2, 2007 | 07:52 AM
  #21
fonseca's Avatar
Very clear DIY. I would recommend that people not reuse the existing valve cover gasket though. I did (since mine was basically new), and a week later noticed oil leaking at multiple locations.
Old Mar 28, 2007 | 11:07 AM
  #22
alpineboarder's Avatar
Vehicle: 1999 Hyundai Elantra
How was your mileage affected by the new cam?
Old Apr 28, 2007 | 08:45 PM
  #23
enigo's Avatar
Vehicle: 97 Tiburon Fx
Sooo... another lesson learned the hard way.
Didn't have a torque wrench, but I tried to go ahead and do this install anyways. Everything was going fine until the very last bolt, which I over-torqued and ripped the threads out of the hole. Not all the threads, half the threads. The bolt won't tighten down, just spins, but it won't loosen with finger pressure (ratchet wrench clicks past it).
The one circled, like I said the very last one.
Then, one of the holes in the valve cover going to the timing belt surround stripped as well. It wouldn't tighten the gap down, for some reason the spacer didn't snap in, so it looked like it had a fair ways to go... so thats messed up as well now. And... the valve cover cracked on another one. Slight hairline crack...
I believe I'll have to retap the hole and go for a slightly larger one bolt... the gasket seal is pretty good still, but I'll just have to replace the valve cover when I see someone selling one.
(to cap it off, 2 of the spark plug cover bolts disappeared, and one of the valve cover bolts fell down into the engine somewhere... I'm going to have to find it tomorrow)
Old Apr 28, 2007 | 09:07 PM
  #24
nate704's Avatar
wow you messed up big time man!
The bolts that hold the cams are very critical parts because the cams spin at high rpm. If you don't fix it RIGHT, you might end up replacing the whole engine including internals.
Old Apr 28, 2007 | 09:33 PM
  #25
enigo's Avatar
I know... I know...
I was wondering if I could fill it then retap it at normal size, what fill could I use? Or just better rethread it at larger size and find a bigger bolt?
What about the metal shavings? ...
Old Apr 28, 2007 | 09:38 PM
  #26
'treezy's Avatar
Ooo, someone finally beat me. LOL. I stripped the threads for the tensioner pulley and had to re-tap the hole in the 4 inch space between the side of the head and the engine bay. yeouch.
Even after I fixed it right, the cheap timing belt I bought broke down and failed days after. Here I stand...
oh, and those valve cover/spark plug cover bolts. I've lost MANY of those (but not in the engine.. lmao.gif), and found a hardware store that has the exact bolts in shiny silver! yay. tried home depot.. tried Ace... but TrueValue is where I found what I needed. ANY BOLT IMAGINABLE, they'll MAKE you a bolt to your specs if need be. They have like 4 aisles of their store dedicated to nuts and bolts.
And you get shiny new silver ones!
oh and use a magnet for metal shavings. and lay down LOTS of protection for the inside of your valvetrain before tapping.
Old Apr 29, 2007 | 11:53 AM
  #27
enigo's Avatar
I don't think I can actually get a proper fill in... I'm going to have to go for a bigger hole with different bolt. (makes me wonder about the other threads, I tightened this one the same way I tightened the rest of em, but this one gave...)
I can't heat it up hot for any fill I can think of enough without burning all the oil around it...
TrueValue? I don't think they have that store in this area, never heard of it... I'll have to search on that one.
(one 20 mi from here, not bad)
Got a guy 2 miles from me who'll rethread the hole long as I come to him.. (heli coil)
Question is, do you guys think I could make that drive? Bolt is too long to get out of its hole (valve cover stops it) and the chain guide which is well secured (not pictured) is helping hold down the bracket.
I just ran the car for a couple minutes (was really rough, forgot to reset the ECU) and I opened up the valve cover and everything is the way I left it. Seems I did the install correctly, minus not having a torque wrench.
I'm thinking it'd make it, but would like a second opinion...
Old Apr 29, 2007 | 12:11 PM
  #28
BlizagaXx's Avatar
Vehicle: car
take off the head and bring it to him. or get it towed. I would <u><span style="font-size:14pt;line-height:100%"><span style="color:#FF0000">NOT</span></span></u> drive it there. That is asking for disaster. I think you shouldn't have even turned it over at all. That cam is spinning thousands of RPM's dude, and those bolts are holding the journals down, which means that cam might be moving 1 thousanth of an inch every hundred rotations, or whatever it may be, and it will start grinding away at the cam which is machined perfectly. dont do it dude, see if you can tow it with a truck you have, or a buddy has, or yank the head. I would not drive it though. That's asking for a disaster man...
Old Apr 29, 2007 | 02:37 PM
  #29
enigo's Avatar
Ya, decided best to push/tow it that distance... wake up at 6 and get an early workout laugh.gif
Old Apr 29, 2007 | 04:50 PM
  #30
'treezy's Avatar
or you could just heli coil it yourself. First time I stripped a hole in the head, I was like "WTF is a helicoil?" went to TrueValue and found out. It's a pretty straightforward process. Nothing you can't figure out (I mean you can swap cams, ..sorta).
you're basically buying threads and a matching bolt and after inserting the threads (looks like a mini slinky but not bouncy like one) you just screw in the bolt, ta da. And it's harder to overtorque them once they're in.
