Front Marker Light
Old Aug 12, 2005 | 12:13 PM
auburnfan's Avatar
After seeing this several times it was time to fix it for good.
First remove your lights by taking out the screw and the pulling from the area that the screw was at. On the driver side pull right to left and then the reverse for the passenger side.
Second I took a hairdryer to them to get rid of the majority of the water then took a couple Q-Tips to get out the remaining water.
Then run a small bead of silicon around the edge of the lights. I noticed on mine that there was a huge gap.
Let dry for at least 30 minutes then reinstall in the reverse order that you took them out.
Again I hope that this helps some people out and I hope that I did a good job on this one for it is my first DIY.
Old Aug 12, 2005 | 12:30 PM
rallyman's Avatar
Good job! Excellent write up! I have the same problem with mine so I'm going to follow your advice.
Old Aug 12, 2005 | 02:19 PM
nicely done, added to the listing.
Old Aug 12, 2005 | 02:40 PM
Mr_Hyde_NT's Avatar
thanks, i had the same problem with the right one long time ago.
I was guessing to do something like that, but since i replaced the bulb with a leds one, i noticed that it is disappeared by itself...
So i have thought that it was because of our weather conditions especially in sept/oct... because *strange but true* i never noticed it on summer...
but i think i will do this anyway if this is the definitve solution wink1.gif
Old Aug 12, 2005 | 02:42 PM
We need to start adding pics from DIY's to the actual site, so we don't lose them.
Nice job mang, I've got a set of brand new ones I'll do that with.
Old Aug 18, 2005 | 06:17 PM
auburnfan's Avatar
UPDATE:
Almost a week later and several days of storms and showers here and no fogging of lights looks like it worked.
