Diy Requests
Old Nov 15, 2007 | 12:10 AM
  #31
This thread is for MAINTENANCE DIY REQUESTS, as it says under the thread title.
Read guys, really.
Use the search engine too, it DOES work.
Old Nov 17, 2007 | 12:44 PM
  #32
bassboy3313's Avatar
Vehicle: 1997 Hyundai Tiburon FX
Could someone show me step by step how to replace a front tie rod on the 97 tibby fx?
Old Nov 17, 2007 | 01:06 PM
  #33
I could do one. Not sure when though. Im doing ball joints in a couple days probably too. Its not to hard though. Just pretty much replace it and probably get it alligned again. Outer tie rod right?
Webtech probably has step by step. Username is RDT password is tiburon. hmaservice.com
Old Nov 17, 2007 | 01:35 PM
  #34
yeah i am pretty sure its the outer tie rod on the drivers side. that would be great man.
Old Dec 11, 2007 | 07:33 PM
  #35
I'd like a DIY on how to clean fuel injectors once they're out of the car.
Old Dec 30, 2007 | 09:34 AM
  #36
Bullfrog's Avatar
Vehicle: 2001 Tiburon
DTN,
There is a special machine that cleans them. A flow bench or something of that sort. Friend of mine used to work at a shop that cleaned train engine injectors and they used the a bench.
Not to bring up a dead horse but a comprehensive with picture and input from members on doing wheel bearings. Something following the thoroughness of Patreezeys timing belt DYI. There are a few posts here and there about it. If someone posted one and its hidden by all means owned.gif my ass and let me know where it is.
Old Dec 30, 2007 | 01:39 PM
  #37
^^ After doing some research I found that the best way to clean injectors out of the car is using a ultrasonic cleaner. Although I work with medical US cleaners and they would work, i could not obtain one for use with automotive parts. I ended up using a few drops of straight sea-foam in the input end, and soaking just the tip, I let the seafoam soak in for a few hours, and sprayed out the injector wth an air compressor. I soaked my fuel rail in seafoam and sprayed it out as well. I believe that will be satisfactory.
Hyundai recommends running your car on their 14PSI special fuel injector cleaner connected to the fuel rail. It does not make sence as the stock fuel pump supplies 38PSI. Seafoam removes carbon well and does not harm seals, so this method should work fine for cleaning injectors. I wish I had taken pictures.
Old Dec 30, 2007 | 09:34 PM
  #38
Bullfrog's Avatar
how hard is it to pull out the injectors?
Old Mar 3, 2008 | 01:56 PM
  #39
tibbymat's Avatar
well, starting this weekend i am going to be doing my custom stereo fiberglassing in the trunk. DTN's angel eye headlight install, custom center console for i pod. and if i have the brains to do it, ksport coilover install.
if anyone wants a DIY picture for picture on any of these let me know and i will get on them. center console will take me about a day or 2 to do. stereo will be about a week or 2 and coilovers shouldnt be more than a day or 2. so this should all be done by the end of the month! fing02.gif
Old Mar 3, 2008 | 08:41 PM
  #40
do a search for me and "ksport". it might give you a little help.
