DIY : Rear View Mirror Vibration (PICS BACK UP)
Old Jul 23, 2004 | 01:03 PM
tibwrcsbj's Avatar
Default Re: Tiburon SE 2000 CAI
Rear View Mirror Rattle and Vibration Fix :
Tools Needed :
1 Small piece (4"x4") of Dynamat Xtreme or similar product
1 Phillips screwdriver w/ a medium sized tip
1 Box cutter knife or xacto knife
6" Electrical tape
1 Pen
1 Pair of needle nose pliers
? Corona
1 Clamp (optional)
20-30 Minutes of your time, depending on how many Coronas you feel like having :-)
Step One : Remove rear view mirror
This is accomplished by pushing on the base of the mirror where it hits the windshield and pulling on it towards the engine (parallel w/ windshield)
I found this much easier to do if the mirror was turned completely around. (also note where i plan to put my Rd.com sticker)
Step Two : Disassemble mirror attachment mechanism
There are four pieces to this. One screw (gold in color), one metal ring that the screw sits in, a round pressure clip, and the actual mounting piece. Be careful pulling the pressure clip out b/c its a b**** to get back in, so try to bend it as little as possible.
Unscrew the screw from the mirror.
Remove pressure clip. Use the needle nose pliers and squeeze it and pull a little bit on one side, it should come out fairly easily.
Remove the ring.
Step Three : Dynamat
Ok, this is the most time consuming part of this whole process.
1.) Lay the ring on the piece of dynamat and trace and cut around it. Apply to ring. Use the pen to press a hole into the dynamat for the screw to go back into.
2.) Lay the mounting piece face (side where pressure clip fits) down on top of dynamat and press down as hard as possible (use a clamp if you have one). Cut out the inner part of the indentation you just made and place this into the mounting piece, flip over and cut out the circle.
3.) Take whatever dynamat you have left over and remove the foil side (should be left with a tar like substance, you may have to peel some of this off as you go.) On the side of the mounting piece that has three dimples in a triangle, apply the dynamat substance in a thin layer over everything except the hole for the screw.
4.) Get the electrical tape; apply some to each of the bent up portions of the pressure clip (I believe this is where most of the rattles come from)
Step Four : Reassembly
Put the metal ring back in (should now be covered w/ and sitting on dynamat)
Depending on how much electrical tape was used you may want to put the screw back into place before putting the pressure clip back in.
This is the hardest part of this whole process : Put the pressure clip back into place, its a PITA, but w/ a little elbow grease and a couple of tries it will go back in. It should now look something like this :
Reattach the mounting piece to the mirror by squeezing it, removing any excess of the dynamat tar, and then screw it back together.
Go put the mirror back in your car (Opposite of Step One but use more outward pressure, took me a couple of tries to get it stay) and enjoy not having any rattles from it, and barely any vibration from it either.
threw the worst i could at it and the little bit of vibration thats left is BARELY noticable, my side mirrors are 50x worse than the rear. BTW i'm sure this could be easily adapted to do the side mirrors too.
The worst i could throw at it :
TCM (vegas and legion of boom)
TCB (singles)
Prodigy (fat of the land)
NWA (efil4zaggin)
Dr. Dre (both chronic albums)
Luke (couple songs off a mix)
Beastie Boys (check your head)
Disturbed (the sickness)
(No SW yet, you figure it out, but i will, prob tonite 8) )
The main reasons i did this :
1.) i'd seen on other sites people complaing about it
2.) those same people said it could NOT be helped, BS
3.) b/c i was very tempted to just pull the mirror off and drive w/o it, it was rattling so bad.
Old Jul 23, 2004 | 01:07 PM
Default Re: ALL OLD MODERATORS, CHECK IN!
Pics no worky GI.
Old Jul 23, 2004 | 01:17 PM
tibwrcsbj's Avatar
Default Re: Sparco Seat Brackets
see red type above........REDZ.....and i wasnt finished yet focker. I do need java to move them for me...they are no longer showing up on the old site either.
Old Jul 23, 2004 | 01:29 PM
supercow's Avatar
Default For Sale Forum Rules
cool, get those pics up!! laugh.gif I'll be interested in doing this one when you do.
Old Oct 28, 2004 | 02:27 PM
TibRacer01's Avatar
Default Re: FS: NX Wet Kit w/ purge kit and bottle gauge
Any word on the pics yet? I am planning on doing this this weekend.
Old Oct 28, 2004 | 02:38 PM
tibwrcsbj's Avatar
Default Re: engine light on.. possibly CAI?
see my post here :
http://www.rdtiburon.com//index.php?name=F...c&p=21008#21008
Old Nov 1, 2004 | 12:23 PM
tibwrcsbj's Avatar
Default Re: Changing map light
Bump, for those of you who were looking for the pics last week.
Old Nov 17, 2004 | 01:15 AM
Talux's Avatar
Default Re: Everyone with a header come in here !
Will be doing this tomorrow hopefully it works good, ATM whenever my bass hits the mirror rattles smile.gif
Old Dec 10, 2004 | 03:15 PM
Shadohh's Avatar
Default Re: Oil Pressure Gauge HELP :)
Good mod.
I been wanting to do this for a while. I found a similiar write up for a WRX.
The first step on removing the mirror was a little confusing but I got it off.
Now I just need to go drive and see if it improved it well enough.
Old Mar 28, 2005 | 06:05 PM
supercow's Avatar
I just got done doing this for the second time first time I used electrical tape laugh.gif: , did ok, but it wasn't enough. sooo I've been looking, I found some rubber stuff to use for free and ended up making a gasket more or less and put it between that plate and the mirror. No more vibration at all now, not even to the touch. (before when you would touch the mirror while driving down the road you could feel the vibrations)
anyways thanks for the info. laugh.gif:
