DIY RD2 Clear corners in 30 minutes
Old Sep 13, 2004 | 02:08 PM
Mr_Hyde_NT's Avatar
Default Re: GB:Garrett T-25 Turbos
I always prefer clear headlights, and mostly the turning signal aways clear..
While i crashed last week @ 30kph i need a new right headlamp and right CC . so with the broken one i'm working for a led integration.. i'm working with the dremel to put some white or blu HE blu led.. i just did a test.. they look really bright .. a lot more than thought lol.gif
when off the led are completely transparent. i must decide if try with white to make a sort of daylight driving lights, or blue only for "showroom", anyway..i'f i'll do something *decent* to see.. iìll put some pics here 8)
Old Nov 8, 2004 | 07:21 AM
tiburonguy01's Avatar
Default Re: Java's Clearance Sale
Hey i just tried this with out the oven step and if you very carefully pry the lens off the backing it will pop off. then you just pry off the orange reflector. I made the mistake of using CA glue to re-apply the lens to the backing and the CA glue fumes adheared to the inside of the lens and turned it an awful white color. but if you use a different type of glue it turns out awesome. it took me a total of 12-15 minutes to do the whole thing start to finish.
Old Nov 11, 2004 | 09:17 AM
TibRacer01's Avatar
Default Re: Just Some Custom Interior
I am going to try this on my taillights this weekend (There is moisture in the passenger side one and I want to clean it out and reseal it).
If that goes well, I will probably try this as well.
Old May 15, 2005 | 08:24 AM
gmantibby's Avatar
I have moisture in my passenger side oem fog light do you think this technique will work for me??
Old May 24, 2005 | 05:59 PM
01blacktib's Avatar
do you think a heat gun could produce similar results. we don't have ovens in the barracks
Old Jun 2, 2005 | 08:34 PM
NBCTibby's Avatar
I was just thinking about doing this today, but I was gonna use a dremel tool and cutting discs and no oven....Thanks to phorq, I am thinking about makin em purple!
Old Jun 27, 2005 | 08:22 AM
auburnfan's Avatar
What kind of glue would be the best to reseal the lens? With no fogging from the glue and no condensation after reinstall.
Old Jun 27, 2005 | 08:29 AM
Epoxy, then seal it with silicone.
To be honest, I've never seen a set of DIY Clears that approach how good the OEM Clear Corners do. The DIY ones end up with this nasty plastic line inside of them, and almost always some yellow chips left in them. You end out putting more time into them than they are worth.
Old Apr 28, 2009 | 09:25 PM
Jumpball35's Avatar
this DIY really helped i did mine to weeks ago
