DIY - Oil Catch Can
Old Jan 19, 2005 | 04:31 PM
x7xstring's Avatar
<div class='quotetop'>QUOTE (tanc)</div><div class='quotemain'>ill post pics of mine after the install this weekend</div>
Please do, ...
I am going to do this mod for sure, I have noticed alot of oil getting in the intake/TB. I have almost 200,000km on my engine, and this will definatly help.
Old Jan 23, 2005 | 03:52 PM
x7xstring's Avatar
Got an update Tanc?
(bump)
Old Jan 23, 2005 | 05:01 PM
Tibbychick's Avatar
you can kinda see mine in this pic. Its behind the strut tower bar, towards the right. Directly above the purple throttle body.
Old Jan 25, 2005 | 10:56 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Im working on it right now as we speak...PITA to find a spot to mount it condcidering the new tib I just bought it all stock so far
Old Jan 25, 2005 | 11:01 AM
Tibbychick's Avatar
mount it to the firewall. Thats where Im gonna mount mine. I never mounted it in the black tib, just kinda let it sit there. The tubes supported it so it sat up straight most of the time. My only concern was that it didnt get in the way of the butterfly valve on the throttle body. Make sure yours doesnt by zip tieing the tubs away from it or routing them elsewhere.
Old Jan 25, 2005 | 11:02 AM
JalemX's Avatar
what did you use to mount it? drilled holes/screws? if you look at the catch can it doesn't look like it's easy to mount there are no screw tabs.
Old Jan 25, 2005 | 03:41 PM
tanc's Avatar
Here are the pics
I found that place to be a good spot for it because I didn't want to drill in the firewall and mount it with a U Clamp. If this setup doesnt work then that's what I'll do. For now all the hoses are in a good place. Ill see how it is in a month.
Old Jan 25, 2005 | 03:52 PM
I'd go change your oil real quick.
That one tube is perty long, but that should be okay as long as the one going INTO the catchcan is short.
Old Jan 25, 2005 | 03:57 PM
is it really necessary to route it back to the intake? as long as the thing is doing its job, i would leave that other hose off.
Old Jan 25, 2005 | 04:03 PM
tanc's Avatar
[QUOTE=REDZMAN]I'd go change your oil real quick.[QUOTE]
change my oil??
and yes, I don't have to route it back to the Intake but I just didn't want to plug the whole. I might tune it later on...but I just want to see how this runs.
