Diy: Independent Foglight Control
Old Jan 15, 2009 | 09:56 AM
StrikeEagle's Avatar
It's gotta be a fuse, replace the critical ones, even if they don't look broken, there's a chance that they are. Is a tail light out as well? If so, that's definitely a fuse, if not, I have no idea...
Old Jan 15, 2009 | 10:25 AM
kcr's Avatar
kcr
Hmm I will check. But the thing is, the turn signals work when turned on. So thats throwing me off.
Old Jan 15, 2009 | 12:38 PM
BlueRD2's Avatar
You could use an ez splice connector instead of stripping the black wire.
Easy splice connector
I know if i was trying to strip just the case of the wire, there would be a huge chance of me just cutting the wire. LOL
Old Jan 15, 2009 | 02:42 PM
kcr's Avatar
kcr
Alright so I guess this doesn't work on a '97. sad.gif I blew fuses and one headlight out. Oh well.
Old Jan 16, 2009 | 01:19 PM
frozen's Avatar
Vehicle: 2001 Tiburon
Actually it looks like you're using the wrong wire. According to HMA you should be using a Red/white striped wire instead of the pink wire, not a blue and red striped wire.
edit: After a quick run through each year's wiring diagram, here is a list for the wires needed to be capped off and replaced with a ground, for each year.
97 (1.8 + 2.0) = Red/white
98 (1.8 + 2.0), 99 = Brown, Blue, or Black (the color is only listed as B, however I would assume Blue or Brown as black is usually reserved for ground))
00', '01 = Pink
Hopefully someone with a 98 or 99 can find out which color the wire is.
Sorry for the confusion, I thought I was only providing info for RD2 owners in the original thread. Strike probably should have checked the diagrams to make sure this worked on other models before posting this general DIY.
Old Feb 12, 2009 | 10:25 PM
BlueRD2's Avatar
Did it today and it worked, Cut the pink wire and ez spliced it to the black. Fogs come on with parking lights now.
offtopic.gif Thought I broke the rear window defogger but the car just has to be on.....who knew...
Old Feb 12, 2009 | 10:50 PM
rusomen's Avatar
here's the wiring for fogs on 98 tib
Old Feb 12, 2009 | 11:19 PM
jalmir's Avatar
Vehicle: Hyundai Elantra 2000
<div class='quotetop'>QUOTE (daneeboy83 @ Jan 13 2009, 04:16 AM) <{POST_SNAPBACK}></div><div class='quotemain'>I found out there is no fog lamp bracket and no wire harness.
I asked a hyundai mechanic to fit and make brackets for me.</div>
Thats because on the 99-00 Elantra the fog brackets are on the bumper brackets, so to install the fogs to OEM fitments you'll have to remove the cover bumper and change the bumper brackets ... the brackets are around 25$ each if I remember correctly!
Old Apr 19, 2009 | 01:49 PM
badshah's Avatar
Vehicle: 1997 Hyundai Tiburon
Nice writeup... My foglights go on with parking lights, stock and never touched the wiring
Old Oct 13, 2009 | 10:26 PM
drpapadakalis's Avatar
im trying to get this figured out ill let you all know how it coes out cause i have a 97 too ill keep you all posted wish me luck
