DIY Fog Light Lens Resurfacing
Old Mar 8, 2005 | 10:14 AM
tibbytib's Avatar
Actually, I left them in the bumper. The most abrassive material you are using is the scotch pad, and if you are careful you shouldn't hurt the paint on the bumper. Also, my car is white, probably the most scratch friendly color out there, so I wasn't worried too much. Even if you did get a few small scratches around the fog light, its nothing that the Scratch Out won't remove. I actually use that Scratch Out about every two years to remove ALL scratches and swirl marks on the car. Takes me about 5 hours, but it literally looks like it just came from the factory!
Old Mar 9, 2005 | 12:26 AM
Viper's Avatar
Jeah, I still don't understand why some ppl wash their cars in the carwash 02.gif
really messes up your paintings, you can see very light scratching on the car after getting it out. They use large rotating brushes here, I think in the US it's a bit different.
Old Mar 9, 2005 | 12:42 AM
2bits's Avatar
<div class='quotetop'>QUOTE (tibbytib)</div><div class='quotemain'>I actually use that Scratch Out about every two years to remove ALL scratches and swirl marks on the car. Takes me about 5 hours, but it literally looks like it just came from the factory!</div>
Where are you getting this magic stuff from? WALMART?
Old Mar 9, 2005 | 07:51 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
So this doesn't work on the head lights?? I don't see why not. Just more work IMO.
Old Mar 9, 2005 | 08:33 AM
Viper's Avatar
<div class='quotetop'>QUOTE (silvertibbs)</div><div class='quotemain'>So this doesn't work on the head lights?? I don't see why not. Just more work IMO.</div>
This exact DIY won't work for the headlights, you'll just have to scratch longer. Technically it would be another DIY if you change the time for scratching laugh.gif:
Old Mar 10, 2005 | 02:29 PM
tibbytib's Avatar
Of course Wal-mart! Isn't that where everyone goes for their high performance and state of the art car nourishing ointments?!?! wink1.gif Also check out 3M Surface Refinishing Compound, also found at Wolly World. Same Stuff. The Scratch out is a bit more abrassive, so it takes care of larger scratches and larger areas quicker. I normally go once around with the Scratch Out and then once around with the 3M. The 3M really puts a mirror coat to the finish. Its cheap too! Only about $2.25 for the Scratch Out. Use it on paint, plastic, laminated woods.
Old Mar 12, 2005 | 04:03 PM
morningla's Avatar
Vehicle: na
guys, Plexus, a plastic cleaner works really good on headlight lenses, it buffs out shallow scratches really easily. I used this on my previous car's headlight. My only complaint is that if the lense is too old, the clean looks goes away after a month or 2...
Old Apr 17, 2007 | 05:30 PM
idremel's Avatar
Old Jul 9, 2007 | 10:33 PM
kris32188's Avatar
yea could you put the pics up again. I'd really like to see the difference. im interested in if resurfacing the headlights cus im having a hard time seeing with my HIDS. I have never been in an accident and they were professionally installed/and just recently readjusted. I just have no idea why!
Old Dec 29, 2007 | 11:00 PM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
