DIY: Corner Removal (PICS)
Old Jan 11, 2005 | 01:30 PM
MrPSXplyr's Avatar
Default DIY: Corner Removal (PICS)
There's a lot of DIY's in here that are for making your own clear corners, but I think some people just might want to know how to take out the OEM corners. I took pics of my corner removal a long time ago, and I've still got the pics around but never got around to writing up the formal DIY. So here it is.
Tools Needed:
- Small handtowel
- Screwdriver (Phillips)
- Some sort of hitting tool (perhaps your hand)
The explanations are on the pics themselves.
Old Jan 11, 2005 | 01:31 PM
MrPSXplyr's Avatar
Default DIY: Corner Removal cont'd
Some people might be weary of using the screwdriver-as-leverage method, but the alternative would be just to use your hands and pull the corner light straight out. All that is holding it in is a little metal ball joint that snaps into a socket on the headlight. You'll see it when you remove it.
As always, questions, comments welcomed.
Old Jan 11, 2005 | 01:40 PM
UltraTibby's Avatar
Nice write up. I wonder if that is what that little plastic knob is really for.
Old Jan 11, 2005 | 03:20 PM
Nice mang, thanks. I had pics but never wrote it up.
Bout time someone did.
BTW, that knob, if you look at it, is connected to the little air hole.
Old Jan 11, 2005 | 03:22 PM
UltraTibby's Avatar
Bstards! Is that why I have water in my damn lamp? Because of that little rubber thingy? If so I will make sure that is filled before the clear corners go on LOL
Old Jan 11, 2005 | 03:28 PM
Pyro's Avatar
oh where was this 2 weeks ago damn i just unscrewed the one screw and pulled like a mother ****er and it eventually snaped some little plastic piece and came out. everything still works fine so i dont thik i screwed it up to much
Old Jun 27, 2005 | 11:24 AM
auburnfan's Avatar
Great post and pics on how to get those dang things out.
Old Jun 27, 2005 | 03:20 PM
tb1198's Avatar
<div class='quotetop'>QUOTE (REDZMAN @ Jan 11 2005, 05:20 PM)</div><div class='quotemain'>Nice mang, thanks. I had pics but never wrote it up.
I think the "air hole" is there so you can fill up on blinker fluid!
Old Jun 27, 2005 | 03:38 PM
'treezy's Avatar
see all this time I thought the wire you plug in and that screw were the only things holding the corners in place....haha.
No wonder it's so loose and looks out of alignment. Where can I get those rubber thingies...mine must of fell out or I lost some clips or something. It makes the front end look really bad.
Nice DIY,
Old Jun 27, 2005 | 08:57 PM
Just thought I would add.. more or less the same for the Rd1. Maybe even a little bit easier as our corners are abutted up to the headlamp.
