Diy Clean Your Pcv Oil Drain
Old Jan 9, 2008 | 10:12 PM
archsvile's Avatar
I've just gotten a new intake recently (injen) and removed my AEM intake because my filter always got wet from the rain. When I removed the intake there was a lot of oil on the inside of the intake before the MAF... but it was more like a grease. I'm guessing my pcv oil drain is clogged? I do have 106,000 miles on my car haha.
Old Apr 2, 2009 | 05:30 PM
JC1206's Avatar
Anyone have any info on reinstalling the valve cover? What I like to hear know about is installing a new gasket and where the RTV sealant goes. I couldn't find any info in the shop manual (no specifics) but the Autzone guide gives a nice diagram. What it doesn't mention is if any sealant goes under the spark plug hole gaskets. I never changed the valve cover myself before and don't want to mess it up.
Old Apr 2, 2009 | 06:08 PM
Search. If you don't find anything on Valve Covers and installing them, you searched wrong, search again.
I've never used any RTV and have had my valve cover off a dozen times or so. No leaks. It doesn't come with RTV stock, so I don't know why you'd need it.
Shouldn't this be a new thread?
Old Apr 2, 2009 | 09:56 PM
Well that explains it. I installed a bad@ss separator on my PCV line and I get literally drops of oil per month, whereas some people get like a cup a week or whatever.
If you get a lot of oil in your external catch can, do the cleaning described in this DIY.
Old Apr 6, 2009 | 08:59 PM
JC1206's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>Search. If you don't find anything on Valve Covers and installing them, you searched wrong, search again.
Shouldn't this be a new thread?</div>
I searched for this topic and this was the only thread where this topic was remotely discussed. Besides I thought this post was relevant because reinstalling the valve cover is part of the procedure anyway. Can you explain what you mean by searching wrong?
Old Apr 29, 2010 | 05:02 PM
AcN's Avatar
AcN
There's what appears to be a silicon joint... What kind of joint is that exactly ? Mine cracked and was tearing apart while removing the separator from the valve cover... Looks like some silicon we use in bathrooms lol, but need to know to fix it ^^
Old Apr 29, 2010 | 10:37 PM
. . . and the joint is located _________ . . .
^ you left out the rest of your post.
Old Apr 30, 2010 | 01:26 AM
AcN's Avatar
AcN
oops, sorry >_____<
as seen on DTN's pic, it's the black lining (mine was reddish and dried to death)
Old Apr 30, 2010 | 07:15 AM
I installed a catch can on my PCV and have not yet cought a drop of oil. I originally installed it on my breather but when I cought nothing, I changed it to the PCV. Seriously. A catch can is a worthless add-on if you have a clean PCV drain. The PCV drain functions as an internal catch can.
Also, I drilled a hole right above the PCV drain and filled it with a generic plug from the "Help!" section at Advanced Auto Parts. The plug allows me to swab with a pipe cleaner. I should post a pic or something.
Old Apr 30, 2010 | 07:19 AM
AcN's Avatar
AcN
DTN, any idea what is the material used in the joint shown on your pic just above ? The black lining at 3mm from the edge tongue.gif*
Anyway, nice to know a nitrous car doesn't need a catch can with a clean PCV drain
