video cards with HDMI
Old Sep 30, 2011 | 02:27 PM
batman's Avatar
Vehicle: 01 Tiburon
Default video cards with HDMI
i want to know if i would need a special cable to get audio onto the video card before transmitting to a tv.
i do not know anything of this subject. would i need a cable to connect to the video card internally or can video cards transmit audio via hdmi without buying extra stuff?
i would like to get a new video card soon, most of the ones i have seen seem to come with mini hdmi to hdmi adaptors.
Old Sep 30, 2011 | 04:29 PM
I've built a few computers with HDMI. I've used ATI cards and never needed to connect anything extra to the motherboard to get audio to come over HDMI. I did have to manually select the video card HDMI output from within Windows though on a couple.
Old Oct 1, 2011 | 10:08 PM
Agronis's Avatar
Vehicle: 2013 Sonata Limited 2.0T
187 has the right idea..
If you spend the money on anything decent, so $75+ at this point the audio should be fully integrated. You'll more then likely have the option to split the audio through the HDMI + Soundboard but obviously you want it synced as much as possible. Just about all the boxes at this point will stipulate whether or not its integrated audio compatible. So no, all you'll need is an HDMI cord.
Old Oct 2, 2011 | 08:17 AM
In Windows you can only output to one sound device at a time, so it will ne the HDMI or onboard audio more than likely.
