Kspec
I just got my trans inspected and a new clutch put in, but they told me that my poly engine mounts were blown out! I just put them in last spring. I don't know what happened, but i am pissed because they were $200 and are supposed to last longer and be more durable than stock....BS!!
how the hell do you blow motor mounts? the only way i can see a poly mount failing is if it gets torn apart somehow. rubber will actually wear some, poly really doesn't. but i cant even imagine what would cause a poly mount to get torn apart.
i think they are trying to pull a fast one on you, or installed them bad the first go around. don't pay them anything.
Your kidding me right? Theres no such thing as blown out poly mounts. As tibby01 mentioned, they are trying to pull a fast one on you, OR you didn't install them correctly.
If you are still concerned take some pics of them and post them up.
