HEADLIGHT warning signal?
Old Nov 16, 2004 | 12:39 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: High Oil pressure
That's cool, it you do it do a DIY I am pretty dumb when it comes to electronics. All I did was burn solder in Elecricity class.
Old Nov 16, 2004 | 01:47 PM
Solo-Baric's Avatar
Default Re: sirius radio
yeah well if i'd do it, it would be on a civic because i don't have my car here.
Old Nov 16, 2004 | 07:11 PM
'treezy's Avatar
Default Re: building a computer
<div class='quotetop'>QUOTE (silvertibbs)</div><div class='quotemain'>My question is why do you leave them on. Cause if it's at night time you should be able to see that you left them on?? I was stupid and never checked. It was really bad when i was going to school. I would turn them on cause I was on the highway. I always like to let people know if there is FUZZ around doing radar. And it is useful too because there are a lot of trucks that use my stretch of the highway.</div>
Of course I'd notice it at night. It usually happens when I'm in a rush to get
somewhere and leave the car without realizing it, like if I'm late 4 work...
which happens quite alot. Anyways, thanks guys...I don't think I'll make a
signal for it, it's not a problem anymore.
Old Jan 12, 2005 | 08:53 PM
Kit-Fox's Avatar
Default Little Yellow Note
how bout putting a sticky note on the window when u leave ur car?
I know lotsa cars have little secret type things, like my dads, explorer sport, to turn of the warning he has to (something like this) turn the ignition to ACC, then off, then to start, then turn on the halogens, then, press the brake pedal 3 times in 5 seconds, then flip on the lights, then turn on overdrive, realy weird shnit like that, same thing for like programing the little beep that beeps when u dont have your seat belts on, maybe there are these programing codes in our Tibs, i know they are kinda secratish, my dad knows them cuz he has the FACTORY manuel not the one that you normaly get.
Old Jan 12, 2005 | 09:06 PM
'treezy's Avatar
what the hell is that?
a sticky, haha....no
Old Apr 8, 2005 | 03:10 PM
99bluTib's Avatar
Has anyone ever set up a buzzer/relay in their 1st gens so this would work? I was told that you could just jam a piezo buzzer's wires into certain fuses(ie. rear defog or wipers and headlights or parking lights) and it would work. Not a fan of the idea of jamming anything into my fuses, so if there is a better method that'd be great. Otherwise I'll just have to learn to double check the lights.
Old Apr 8, 2005 | 04:07 PM
i at first thought it would be easy, but then i thought of something.
you dont want the thing buzzing while your driving and the headlights are on. because of this, it will be harder. im thinking stock, it has something to do with the ETACS. i cant find a thing on webtech about it.
Old Apr 8, 2005 | 09:58 PM
fonseca's Avatar
If you get one of those cheapo $99 installed alarms from Circuit City or Best Buy, they usually have a headlight warning.
Or you could buy a headlight warning kit and install it yourself if you are technically inclined. Several options in the $15-30 range. Here's one. Here's another. Do it yourself for just a few bucks in parts. I'd rather get a kit that had a solid housing and everything I need though.
The easiest install would be to have it warn whenever the ignition is off, but you could also set it to warn only when the ignition is off and the driver's door opens, as per the DIY version.
I disabled the headlight warning in my car, and just set my alarm to always cut power to the headlights and dome light when armed. That's actually nice because then when I go out to my car at night and disarm, the lights cut on to help me see where I'm walking. That's why I haven't bothered to set up the remote headlight activation, which would take up an aux channel.
Old Apr 9, 2005 | 12:02 AM
wec2002's Avatar
IMO one of the easiest ways to deal with this problem is the way Fiat did. Put relays in line with the headlights that are activated when the key is in the run position. Thus you shut off the car and the lights go out. No more dead battery. Just a thought. I would have to do some research but could come up with a DIY if needed.
Old Apr 9, 2005 | 12:22 AM
heh.. I know with my fiat.. if I have the headlights on and turn the car off.. all the lights go off. I can however move the switch to the parking lights and those will come on. It's strange, but it works.
