Wheel Off set??? HELP
Old Oct 30, 2001 | 09:57 AM
BigRed's Avatar
Default Wheel Off set??? HELP
OK, i want to make my rims and fenders as flush as possible and im not gettin rid of my 18's soo is there any other way. I mean look at this pics of tibbys how do they do it???
Thanks agn, Fred!!
[ October 30, 2001: Message edited by: BigRed ]
Old Oct 30, 2001 | 10:51 AM
Stock offset is +42.
The wider the wheel, the lower the offset should be to keep the wheel EQUAL to where it was. In order to move the wheel OUT even more, you need to lower the Offeset even more.
For 7" wheels I would go with a +38 offset
for 7.5" wheels, I would go with a +35 offset
for 8" wheels, I would like to see them fit! *grin*
Old Oct 31, 2001 | 03:10 PM
HA HA..you could always get a wide body kit and then buy some nice 10" wide rims! That would be insane though! eek.gif
Old Oct 31, 2001 | 10:42 PM
True...install the proto body kit and slap some 15" wide wheels. They would probably need a -80 offset to fit, and good luck turning with 15" wide tires and such a severe offset.
Old Nov 6, 2001 | 04:45 AM
Guilty's Avatar
Vehicle: Custom Wagon
What if you went with a 17x7 with a +40 offset and a 205/40/17 tire would it rub or would it sit flush with the fender?
Old Nov 6, 2001 | 05:44 AM
Iago's Avatar
Guilty - with stock no-drop it will look like my Tiburon, because that is what I have.
Even with a drop, I do not remember anyone ever saying they had rub problems.
Old Nov 6, 2001 | 05:47 AM
That would be nowhere near sitting flush with the fender, it would be about where the stock wheels are.
I've said it before, I'll say it again.
YOU CANNOT GET THE WHEELS FLUSH WITH THE FENDERS! If you did, the wheels would bend your fender and your fenders would cut your wheels every time you went over a bump. The wheels are designed to tuck INTO the fenders.
The veilside car posted above is a SHOW car, sure, you could get a set of +25 offset wheels and 225 tires, but I would not try driving to the carshow with them. The car that is an example for the SR tail lights, those wheels fit inside the fender. If you look closely, you will notice they are not flush...but they are so far out I would bet they still rub on bumps on the inside fenderwells.
Old Nov 6, 2001 | 06:36 AM
Guilty's Avatar
Thats cool Random I don't want it to sit flush I just want to make sure they wont rub. Sorry if I didn't make myself clear about what I was asking. tongue.gif
