Two screws on brake rotor
Old Sep 25, 2002 | 05:02 AM
accent_01's Avatar
Vehicle: 01 Accent
Default Two screws on brake rotor
I own a 2001 Accent and I'm trying to put generic/take-off steel rims for winter tires. The rims I got fit Civics, which should have the same specs as my Accent (13x5",4-100 bolt pattern, offset should be same).
But, the only problem is that my rotors have two small screws on them, which prevents the rim from seating properly.
What are those screws for? I notice that they have some blue paint marks on them. If I take them off, put the wheels on and show up to the dealer, would they have a problem?
Thanks!
Old Sep 25, 2002 | 05:35 AM
Solo-Baric's Avatar
probally not. besides if you thing about it what is that little screw gonna actually hold on over time? just take it out and you fine.
Old Sep 25, 2002 | 09:13 AM
Digital's Avatar
Those two Phillips head screws are only there to hold the rotor will it moves along the assembly line. They can be removed without an problems.
Old Sep 25, 2002 | 12:44 PM
accent_01's Avatar
Vehicle: 01 Accent
Some MF-er at the local dealership told me that if I take off the screws, the brake disc will rattle.
After talking to him, I placed an order on rims specific to Hyundais, instead of the generic Honda ones that could have worked just as well (for $100 less).
Old Oct 15, 2002 | 03:10 PM
bozz74's Avatar
I took mine 2 after I bought my tib so I would have to use a spacer on the wheel and have had no issuses. (I have had my tib for a year)
Old Oct 16, 2002 | 09:38 PM
Jerryzcrib's Avatar
Definitely won't have a problem. I took mine off shortly after purchasing it. The rotors never rattled or warped.
Good Luck...
Oh yeah...the back drums will mostly likely have one screw on each as well.
[ October 17, 2002, 04:44 AM: Message edited by: Jerryzcrib ]
Old Oct 17, 2002 | 12:08 AM
ELANTRAVISION's Avatar
When I had my rims installed, those screws were removed. I haven't had any problems, and they been gone for six months.
Like someone said, they are simply for when the cars are assembled.
Old Oct 19, 2002 | 05:40 AM
geo's Avatar
geo
All those screws do is hold the rotor onto the plate that the studs are on so if you take off those screws you can get the rotor off. with the tire on and all lug nuts tightened properly you will have no problems at all
Old Oct 19, 2002 | 06:48 AM
Hootie's Avatar
geo:
Wrong. wink
Those 2 screws hold absolutely NOTHING. I took mine out by hand on all four corners. That is unless you are speaking of CAPTIVE rotors. Then you are correct.
Old Oct 19, 2002 | 09:46 AM
Lower Class's Avatar
Actually those screws can be replaced with longer screms to assist in removing the rotor, rather then using a hammer to. When longer screws are pressed in, the push directly on the knuckle to remove the rotor. Many brake drums also include these screw holes. They can me removed with no problems.
